Bnr k04-gt28
#1928
Just an update. Install is done. I had a timing prob(I installed valve springs while the car was down but did not run it without a turbo so had to wait) that turned out I was off by one tooth down at the crank. Fixed that and I was pleasantly surprised that I got NO codes. None
I routed the vac lines just like you all recommended and everything seems to be working perfectly. I had to make a bunch of tiny adjustments to the BOV cause it was too stiff and I was getting surge. Ive got it to where it bloes off now properly but I still get a tiny amount of surge at low throttle. Not sure if I should make it a tad softer cause Im afraid to affect the higher throttle/boost blow off.
Anyways, I logged with HPT on the stock GMS1 and I was amazed that with all the mods and not being tuned for the CAI and BOV there was no KR. A degree here and there but nowhere near as bad as it was on the 2860. I did replace both round crush gaskets on DP and turbo to o2 housing aswell.
Thanks to all of you who helped me out and pointed me in the right direction! I really apreciate it
#1931
Shes running smoother than she did before lol Alost too quite. I may have to look at eliminating my resonator to get some more turbo and growl
#1933
Nice, I know what your going through bro, I went through the same on my Old Iroc-Z, it sat and sat and sat for almost 5 weeks without been able to get it fixed after blowing some Pistons for having some **** Mech installing a 150 shot Dry, but sold it after a while.
#1938
Personally I'm working on a E35 blend tune atm on my BNR 2871. After I get that ironed out I'm gonna see what I can get out of a 6 pin 2.4 TB tuned.
So if that EFR turbo ends up being $2.2k-$2.5k, I bet 75% of the people will jump ship, ZZP has to make up that money somewhere for the custom casting being made.
So right off the bat its got to cost more then a regular EFR turbo.
But first thing is first, it has to come out.
#1943
yeah that is totally true maybe some cheaper options for bolt on kits for some of the "older" turbos will hit the market, i am still thinking of buying the upgrade, in the next few months, i called atp they said they have no plans of making a bolt on kit for our cars like they do for everyone else which sucks
#1944
I tried APR Turbochargers in Alabama 2 years ago and got shot down with they are sticking with there Euro brands only.
Even though we run a better version of there K04's stock
