Build Date/ Porus-Cracked block question
I am thinking about buying a car I found that is a 2008. It only has 33k no frame damage no flood damage clean car fax etc Never been modified...etc. etc.
I have read about the porus/cracked block issue and I believe the problem build date range is 08/2008 to around 04/2009.
I have been searching for the last hour for that date range as I am probably going to buy the car tomorrow....can someone please confirm the problem date range so I can check this car.
THANKS!
THANKS!
I am thinking about buying a car I found that is a 2008. It only has 33k no frame damage no flood damage clean car fax etc Never been modified...etc. etc. I have read about the porus/cracked block issue and I believe the problem build date range is 08/2008 to around 04/2009. I have been searching for the last hour for that date range as I am probably going to buy the car tomorrow....can someone please confirm the problem date range so I can check this car. THANKS!
That's the most prominent date but it's still a small percentage
jdbaugh1
02-19-2016 08:09 AM
