Bypass Valve Solenoid Testing
Old 01-16-2015 | 01:09 PM
blueLNFftw's Avatar
Ecotec LNF Bypass Valve Solenoid 12633411
Is there a way to test if this part is not working properly?
Old 01-16-2015 | 01:38 PM
09CobaltSS1's Avatar
I hope you weren't running it the way it currently is in the picture. It sure isn't going to do much in it's current state.
blueLNFftw's Avatar
Updated picture to show stock routing; how mine is.
Corey Girard (06-16-2020)
Old 01-16-2015 | 01:43 PM
OK good. lol
The original pic you posted looked like there was no vac/boost source going to the solenoid, with just a line going to the bpv. I was thinking, well, that explains a lot now doesn't it. haha
Old 01-16-2015 | 03:17 PM
Terminator2's Avatar
Have you deleted the vac tank Cory?
Old 01-16-2015 | 03:38 PM
blueLNFftw's Avatar
No. I tried, and the hose from the solenoid to the tank is stuck. And I mean stuck. I seated row 300 for reps and was pulling on that hose with my weight against the bumper, that hose didnt budge.
I was going to try to bypass it and see if anything changed. I am thinking I may just cut the tank end and route it. However, I will never be able to undo the "mod" without buying a new solenoid if it makes things worse tho.
Old 01-16-2015 | 03:39 PM
Try skipping the vac tank first, but iirc you can run the bpv directly to the manifold.
Old 01-16-2015 | 03:40 PM
Yes and yes
Grab a set of pliers and gently twist the line on the nipple. The fitting and hose design you pull and it puts more tension on the fitting, but if you twist and gently pull it should pop right off.
Old 01-16-2015 | 03:42 PM
I had the same experience with those hoses. Take a flat blade and gently pry up on the hose and then spray some soap under it and twist it around and should pop right off.
Old 01-16-2015 | 03:44 PM
blueLNFftw's Avatar
Awesome.
I will try both of those things individually tonight
What should I do about the line that goes to the lower CP when I attempt to try the BPV off of the manifold only?
Old 01-16-2015 | 03:49 PM
Awesome.
Plug it off somehow or cap the nipple on the CP.
Old 01-16-2015 | 04:18 PM
When i was having problems i deleted the tank but i didnt really do much in my opinion. Also did the connect the bypass directly to the manifold it kinda work for a bit i tried it but it wasnt my solenoid that was bad it was my tb. I have a solenoid for sale if you need a spare
Old 01-16-2015 | 08:11 PM
SSlobalt's Avatar
Hey! I made that photo.
Old 01-16-2015 | 08:17 PM
Lol copyright him
Old 01-17-2015 | 08:00 AM
blueLNFftw's Avatar
I'm gonna mess with it today. The inconsistency of my BPV makes me wonder.
Eddie, I'll let you know.
Old 01-17-2015 | 04:11 PM
blueLNFftw's Avatar
Took the vacuum box out of the system and no change (kind of figured this).
I adjusted the wastegate maybe half a tune since it was not quite easy to do. I made the rod a tad shorter. I also took about the Forge BPV and found the yellow spring inside of it. Everyone said that spring causes issues, so I installed the green one, lubed the valve, and put it all back together. It was also pretty much dry and the grease that was in it was more like a paste.
The MAF failing seems to have stopped, I have not been able to get it to do it. The knock is still there. My exhaust shield is super loose under the car, so I am going to fix that tomorrow.
Old 01-17-2015 | 04:32 PM
blueLNFftw's Avatar
I am going to pick up some fittings and remove the boost solenoid from the system to see if that clears things up.
I changed the oil and it was black as can be; also a quart low. It may have been low from being in there too long, but my other thought is that the turbo is using oil. I didn't feel excess shaft play on the intake side when I took the BPV off, but maybe on the exhaust side?
Old 01-17-2015 | 04:55 PM
tomj77's Avatar
lol that's ur only issue? take a knife and cut the hose the long way on the solenoid then pull it.
Old 01-17-2015 | 05:14 PM
blueLNFftw's Avatar
Term and john had it right as always. It's actually gentle that makes it slide off.
There is not enough hose up re attach it of you cut it.
Old 01-18-2015 | 03:40 PM
SSlobalt's Avatar
Man, I don't know if you have the worst luck in the world or if you are making your own problems.
Old 01-18-2015 | 04:06 PM
blueLNFftw's Avatar
Thanks for the useless post.
Old 01-20-2015 | 02:29 AM
SSlobalt's Avatar
Whatever, man. It's you need to take this car to a professional. Good luck getting help on here.
Old 01-20-2015 | 08:24 AM
blueLNFftw's Avatar
I got all the help that I need so if you have nothing to add, kindly stfu with the "take it to a pro" crap.
Old 01-20-2015 | 08:29 AM
blueLNFftw's Avatar
PS.
To test the boost solenoid in question, remove it from the system.
Run the BPV off of the manifold.
Cap the line to the lower CP.
Do it with the vacuum box not in the set up.
If the issue clears up, solenoid is bad. If not, put it all back and look elsewhere.
Or, you know, go pay GM to just throw parts into your car instead like suggested above me...
Snail_SS (05-20-2017)
Quick Reply: Bypass Valve Solenoid Testing
