Change map lights??
Change map lights??
I need help changing the map lights in my car. The only part I can't get is getting the stock bulb out, does anyone have any tricks on how to get them out?? Cause it seems impossible
i used needle nose or curved needle nose, got behind the bulb a bit (so ur pulling on the base of the bulb as apposed to the bulb part).
dont squeeze instead use a lever action beind the bulb and it will pop out
I never changed mine in the cobalt, but in the WRX I just bend the nodes enough to be able to slide it out...
I hope your changing to LED, because it's the best mod I ever done to my interior!
2 x T10 168 194 501 W5W Car White 10 LED SMD Side Wedge Light Bulb Lamp 12V N98B | eBay
these are the ones I have..very bright but not to bright
I have these in a 9 LED version:
30 High Power LED Rectangle PCB Lamp w/ Festoon Base | LED Lights for Cars | 12v | Super Bright LEDs
Costly, but worth it.
