Choosing between ZZP and AutoWerks long block
#126
I can see why op might make this choice. Since he is their test build I assume he would get a really nice price in exchange for a probably slower build because of the issues that are bound to occur with a 1st time build of this level for them. And hopefully once the bugs are worked out he will end up with a quality finished level product.
#127
I wouldn't say you are their test build as far as the motor goes. There are only a few options that you are deciding to go with that I didn't when they built mine. You would however be one of the first to have them slap a big turbo on. Like said before they have built plenty of motors that could take on a lot of power. Your build should be interesting though, they are finishing up my turbo swap this week
#128
If someone has the cash why wouldn't it? What's so special about zzp? Surely isn't your manifold you sold mewarped so bad it blew my exhaust gasket on install and paid 60 bucks out of pocket to have it milled but when I contacted you after 3 attempts and 2 weeks later to get a runaround answer.
You guys definitley do good r&d but holy hell you guys act like you are god sometimes and tour customer service is among the worst I've ever seen when I was doing my cobalt.
#129
As far as your manifold, I know nothing about it, but I do know that if it was bad that we would have replaced it for free.
#130
The build will pan out if he decides to go through. the only way it wwouldn't is if he decides to pull the plug and not come to us for the build. I say that with 110% confidence.
We arent aren't some cobble together hack shop with little to no experience. we have the resources and knowledge.
#132
I did contact about the manifold twice and got a runaround answer both times. And get off your high horse bud there is nothing special about zzp besides modding cars most people don't want to. Start developing parts for Hondas and supras and see how well known you are in the community....
#133
Sound Performance does Supras and LS1s, Titan does Supras, Ill Garage does hondas....and they all specialize in them....as does ZZP with 3800s, Deltas/LNFs/ecotecs.
And just because you don't like them doesn't mean you need to discredit them for their accomplishments. They've developed a massive amount of parts for a dying community of cheap enthusiasts who want everything for damn near free and continue to support and make parts for us.
Bashing is fine, you don't have to like them. But please keep it relevent.
#134
Ok it's cool if you don't like ZZP, but at leaat make sense when you try to bash them. What in the world does development of parts for a honda or a supra going to prove to a COBALT COMMUNITY. The supra/2jz community nor does honda community has no bearing on a delta build.
#135
Considering that you said you had the manifold fixed right away, I bet you emailed us later asking for money or compensation. You were likely told that we need to have parts returned in order to warranty them. Then you probably got mad and decided that our customer service sucks. Straight from the owner, we were told to swap out the old manifolds for the revised ones even if the customer had them for a while. If you can't manage to work with us well enough to make a simple exchange, that would fall on you. I deal with your type often. You want to be a dick to get improved customer service. Sorry, but it doesn't work that way. Not with ZZP.
#136
I never said I didn't like them. I stated that they do great r&d. I said their customer service sucks and if they did develop parts for another community they wouldnt be nut hugged and think they are god like they do with cobalts. Matt apparently thinks no other shop but zzp can build a high HP ecotec. That is laughable
#137
That's actually the exact opposite that happened. I said it was warped and the first answer I got was to check my head. Didn't even acknowledge that retard statement so I emailed again and got told some answer that the flange isn't warped that Ryan vises them down when they cool and then the flange is checked with a straight edge before it sent out. That's when I fixed it myself
#138
#139
Matt and the crew have done extensive research on the platform. And did you expect him to tell the OP to go to werks? Lol
I'm going to use an evo example. Company, pro-efi specialize in subaru. Built a good friends evo. Fully built motor, 64mm turbo, head, etc. Crazy build. The car broke on the drive back under normal driving, was warrantied 3 times, and never ran or made the amount of power it was supposed to (680-800) before he gave up and got away from the shop and went to a shop who did mitsus. They had to redo damn near everything...tuning, torque on bolts in the motor, etc. Then the car started to run right.
Get the point?
Werks does deltas and kappas and I'm sure they'll dl their best here as well. But I know I wouldnt trust a build to TTR for instance.
#140
Instead of sending it in for a replacement. That is what I'm talking about. If you need to have a part warrantied, either send it back or fix it yourself and stop bitching. Claiming that you fixed it yourself and then bitching about it down the road is useless. Furthermore, if you could be reasonable with your relationship with ZZP. Then we would take your word for it and send you a new one and a shipping label to send yours back. People like you that start out by acting the way you do typically don't get far. We would have no incentive to go against policy to please someone who clearly would not return the favor.
#142
It sounds like your hang up is personal and against Matt and the following ZZP has.
Saying you're more experienced than most in this thread sounds pretty high horsed...seeing as many here have quite the bit of experience.
#143
The same could be said for other specialized shops. If ill garage made cobalt parts they wouldn't get "love" either. The point is moot. Bottom line is they are specialized and making parts for 5-6 different markets that they own cars for.
Get the point?
Get the point?
#144
#147
Why do you keep saying he is on his high horse? They currently own/have built some of the highest horsepower lnfs/lsjs and, as you said, do all this r&d, and service hundreds if deltas and other cars.
#148
No, once again, I said nothing of the sort. I will say that we are the only ones that do, but I will never say we are the only one's that can. Obviously if Duttweiller decided to build crazy Cobalts, he could easily put together a 1000whp car for a customer. He would also hand him a bill for 80 grand, so the point is not relevant. On the other hand, can Werks build a 600whp Cobalt that runs and drives great and passes emissions? No one knows because they have not attempted this in the past. My question to you was, "What happens if this build doesn't pan out?" It was a fair question because the customer is taking on a risk by choosing to have his car modified to this level. This questions needs to be asked. FWIW, we would not mind at all if someone asked the exact same question regarding a large build getting done at ZZP. High horse? Not at all. It's more like common sense.
#149
Once again- our phone calls are on a call-back basis. If you leave a message, Steve calls you back. If you call 56 times and keep getting mad, that is your fault.
#150
That's the dumbest **** I've ever heard but ok. I obviously don't hate your shop, I've ordered in the neighborhood of $5000 in parts from you I'm just saying the customer service is lacking and you guys put off the attitude that nobody else is qualified because you built a few fast high hp cobaltss that is all
