Clutch question...
Old 02-03-2011 | 08:44 PM
Mike_peperni's Avatar
Clutch question...
Hi guys,
I have a question regarding clutch for the SS TC, in fact its for my friend and he wanted to know what do you guys would recommend, i have no idea wich one is best, i tried to search and i found some like the spec and zzp...
My friend tend to go with the cheaper he can find but i try to tell him it might not be the best way.... id like to know wich model youd recommend and what part are needed, i remember something about a clutch rod, but im lost with all that... is it needed to have the clutch rod for any type of aftermarket clutch on our car?
He currently have trifecta 24 psi, but will have K&N sri and catless downpipe.
His driving is pretty intense, looking like he is getting away from something all the time...lol like he stole this car... so he need something that will handle more than that i assume...
Thx for any help!
Old 02-03-2011 | 08:55 PM
Dirty25RS's Avatar
A twin-plate will chatter less, be more daily driveable, and do a better job protecting your transmission from shock load than a heavily sprung equivalent torque rating single plate.
this is all I have to say.
Old 02-03-2011 | 09:32 PM
SSlobalt's Avatar
The clutch rod is to make aftermarket clutches engage higher in the pedal travel range, to match the OEM-feel. Most aftermarket clutches engage close to the floor, for the Cobalt, for whatever reason.
Old 02-03-2011 | 10:53 PM
Ok, thank you for the info, he found a spec 3 clutch, cheaper than what ZZP offer with the stage 4, what would be more suited for my friend?
Old 02-08-2011 | 07:20 PM
AyrtonSenna's Avatar
I got the clutchmaster stage 4 6 pucks for 600 $
Old 02-08-2011 | 07:27 PM
Hes going for that same clutch, where you got it?
Old 02-08-2011 | 08:24 PM
batboy's Avatar
Modern Performance has good prices on Clutchmaster. Not sure I'd get the stage 4 though if this is a daily driver. The 6 puck stage 4 is rather "grabby".
Old 02-08-2011 | 08:41 PM
Dirty25RS's Avatar
6 puck is exactly what I was recommending against.
05-28-2022 04:47 AM
Zharrington_2010LNF
02-08-2016 02:43 PM
RaginChopsuey
10-27-2015 02:27 PM
SSLOW06
10-01-2015 08:21 PM
Tupp
09-30-2015 09:18 PM
