Cranks & Cranks then.......!!!
Old 05-28-2013 | 10:52 AM
Nfamous60's Avatar
Well as everyone knows I had to swap out pistons which was done broke hole motor down an used this whole weekend to put her back together. The moment of truth I pull fuel relay crank her a couple times to dr oil flowing put fuel relay in and she cranks strong but won't start... Pull plugs they wet swap plugs same thing so I let her sit overnight for fuel to evaporate now this morning same thing, plugged everything in lines up all timing marks, seems to not get spark but when I test the plugs They spark what am I missing.
Old 05-28-2013 | 12:04 PM
GTOworshiper9's Avatar
How do you know you're getting fuel? And how did you test for spark? Any codes?
Old 05-28-2013 | 12:08 PM
JapEatr's Avatar
South Central *********
camshaft position sensor is out of phase
Old 05-28-2013 | 12:16 PM
when my car would crank forever but not start it was my camshaft position sensor
Old 05-28-2013 | 12:48 PM
Nfamous60's Avatar
Fuel is n the cylinders and I test the spark by putting it n te coil put a bolt thru the mounting hole and touch it to the body when u crank it the plug sparks
How should the cam position sensor be??
Old 05-28-2013 | 06:36 PM
Nfamous60's Avatar
Anyway to test it?
Old 05-28-2013 | 06:45 PM
Omnigear's Avatar
i though you still have warranty?
you went to the hobby shop and did all the work?
Old 05-28-2013 | 06:51 PM
Omiotek's Avatar
Check the crank position sensor, cam position,sensors and can phasers. If they are all plugged in then your motors out of time
Old 05-28-2013 | 11:04 PM
Nfamous60's Avatar
My wont have warranty have to much done now, I did everything myself, friends wouldn't lend a hand except for two, cam phasers are plugged in grey on intake side blk on exhaust side, cam position sensors are plugged in and crank sensor I never touched I kept the motor in the car, timing I aligned the marks the way they need to go, pink with timing mark on exhaust side, green timing mark on intake side an pink at the lower notch on the crank gear...
Old 05-29-2013 | 03:37 AM
Omiotek's Avatar
That doesn't mean it didn't hop teeth when you reset the tensioner. Verify 100% yoor engines in time
sounds to be likes its off. What did you do when you timed it???
Old 05-29-2013 | 08:56 AM
Nfamous60's Avatar
The process I used to time it or what I did after I timed it, I just aligned the marks n put everything together will take her apart this weekend ARMY has sent me to Warriors Leaders Course so days r crammed.
Old 05-29-2013 | 08:59 AM
Omnigear's Avatar
well its 3 major things
fuel , spark and air.
the rest falls under them category
Old 05-29-2013 | 09:10 AM
Omiotek's Avatar
well did you put piston number 1 at tdc when you timed it? its possible to line all the marks up without number 1 at tdc but if you did it that way your motors out of time.
Old 05-29-2013 | 04:11 PM
Nfamous60's Avatar
No didn't put piston 1 at tdc, so it's out of time which means the head has to come bk off to see that?
Old 05-29-2013 | 04:17 PM
Use a pencil/wooden rod through the spark plug hole or at least that's what some old hot rodders will do, not sure how touchy these engines are. Someone with more experience building these can say if this is a good idea on these engines.
Old 05-29-2013 | 04:30 PM
Omiotek's Avatar
the head doesnt have to come back off... the valve cover and front engine cover for sure need to come back off as well as the timing chain tensioner.
you timed your engine with the head on correct? so then theres no reason it needs to come off
take a long quarter inch socket extension(i have one thats like a foot and a half long). stick it down in the spark plug hole for number one and rotate the engine till its at tdc. then start the timing procedure.
Old 05-29-2013 | 04:34 PM
c130aviator's Avatar
if you turned your engine over without the engine timed correctly you have more issue than timing now... you possibly bent valves.
Old 05-29-2013 | 04:36 PM
If you did bend them and you still have good compression, you now will have valve guide wear and premature failure of valve seals, etc.
Old 05-29-2013 | 06:20 PM
Nfamous60's Avatar
Well no crazy metal sounds she sounds like she always does when starting her just won't turn over... Ill try n get sum stuff done today PT Test in morning
Old 05-29-2013 | 06:21 PM
Omiotek's Avatar
IF he bent them. i would recommend a compression test. depending on how far out of time it was he could of done no damage at all or a whole lot of damage. ive made this mistake once in the past on the very first ecotec i timed(followed the service manual and it does not say anything about placing the engine at tdc). anyways did no damage to the guides, seals, valves or anything. again this all depends how far out of time you were. i was like 2 teeth off in the end which is nothing. if your one tooth off the car will still fire and run fine but will throw cam correlation codes. the lnf tends to be a lot different then the lsj.
Old 05-29-2013 | 06:41 PM
He might get lucky and have timing reversed, intake valves open on exhaust stroke, exhaust valves on intake
Old 05-30-2013 | 07:05 PM
Nfamous60's Avatar
Problem was simplier then that, intake cam gear was not all the way on was kind I sideways, started her up after correction and she idles perfectly just hav a gas leak at the fuel Injectors will take off intake mani soon..
Old 05-30-2013 | 07:58 PM
one of those moments
glad it wasnt a huge issue
Old 05-30-2013 | 10:17 PM
Great to hear, so sick of the bad news all the time on this site. You lucked out man!
Old 05-30-2013 | 10:35 PM
Nfamous60's Avatar
Who you telling I was scared as hell I was gonna wait til the weekend but was like nah let me just check took timin cover off and valve cover and was wtf why the chain look crooked, smh like wow really corrected that turned her over and was like YESSSSSSS bout time
Quick Reply: Cranks & Cranks then.......!!!
