Defected from Mustang to Cobalts
I've been a mustang guy most of my life, but I've researched the Cobalt SS/TC the past year. I picked one up, finally, a couple of months ago and damn, I love this thing.
Great gas mileage (not as good as the cavalier I sold), and awesome horsepower available. I was on this site the same week I purchased it and all y'all convinced me to go GMS1. It was installed the next day.
A few things I've run across the past month:
As mentioned in several threads, make sure the TMAP in the cold charge pipe isn't grounding on the AC compressor! I wasn't having this exact problem, but occasionally I was getting a random missfire under load. I finally checked it a few days ago and noticed the TMAP bolt was loose. It was just flopping around. Thanks GM technician! I tightened it down and no problems since then.
Also, the vacuum line that runs from the cold-charge piping to the intake manifold has a bad habit of rubbing on the fan shroud. I re-routed it because a few thousands had already worn off the hose. Just run it behind the AC hose so it won't hit the fan shroud.
Thanks for all the information available on the site! Long live the SS/TC cobalts! Down with mustang 5.0's!
PS - The oil leaks are pissing me off. DIAF GM.
Welcome!!!
I sold my Camaro Z28 and got my 09 Cobalt SS I love this car and have no regrets getting it!! oh yeah did I mention its super fast, great gas mileage and looks sick!
I was 3 sheets to the wind when I made this post, it looks as though I was a little excited, with my exclamation points and all.
I have one pic I took with my crappy phone:
I'll try and get some better ones when the weather lets up.
Thanks for the welcomes!
I've had it into the dealer 3 times for oil leaks. Once for the crank seal and 2 times for the driver side of the head. They replaced the cam position sensor the first time, but now it's leaking again. Probably the cam end plate or fuel pump. I'll probably end up doing it myself with some Toyota FIPG because I can't trust someone to do it right.
Just got done fixing more rattles... it's still a blast to drive, though.
Edit: The cavalier I purchased new in May, 2002 had a 126,000 miles on it when I sold it. The 2.2 Ecotec had no leaks.
i went from a mustang gt to my cobalt ss/sc and i am in love. better mpg and its actually faster than my mustang. wish i could afford a tc but my sc is awesome! there is always twin charging down the road.....lol
I have my 07 Mustang GT and 09 SS/TC. I like the SS/TC better for driving ergonomics and fun factor. The Mustang is built a lot more stout and doesn't have as many quality issues as the Cobalt.
Service Information 2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Document ID: 2371867
#09-06-01-014: Oil Leak by High Pressure Fuel Pump (Reseal Camshaft Cap) - (Dec 3, 2009)
Subject: Oil Leak by High Pressure Fuel Pump (Reseal Camshaft Cap)
Models: 2007-2009 Chevrolet Cobalt SS, HHR SS
2007-2009 Pontiac Solstice GXP
2007-2009 Saturn SKY Redline
2008-2009 Opel GT
2008 Daewoo G2X
Equipped with a RPO LNF Engine
Please Refer to GMVIS
Condition
Some customers may comment on an oil leak.
Upon further investigation, a technician may find oil leaking from the high pressure fuel pump area.
Cause
This condition may be caused by a camshaft cap that is not sealed correctly to the cylinder head, causing oil to leak out.
Correction
•Verify the customer's concern.
•Remove the fuel pump. Refer to Fuel Pump Removal in SI.
•Remove the camshaft cover. Refer to Camshaft Cover Removal in SI.
•Remove the camshaft cap (1). Remove all excess sealing material from both surfaces.
Note: It is critical during installation to ensure the bearing rear cap and cylinder head alignment is correct and the mating surfaces are flush.
• Ensure that all sealing material has been removed from the components and the sealing surfaces are clean and free of contamination prior to applying the sealer.
• Install and align the rear cap within 20 minutes of applying the sealer.
•Apply a 2.5 mm (0.1 in) bead of sealer, GM P/N 12378521 (in Canada, use P/N 88901148) to the cylinder head at the number 6 intake camshaft rear cap mating surface.
Note: Apply the sealer to all locations centrally locating the bead on the rail.
• Run the bead to 5 mm (0.2 in), dimension "a", as shown.
• Where the cap ends on the perimeter rail, extend bead approximately 4 mm (0.2 in) beyond edge of cap.
• Run bead, dimension "c", 32 mm (1.3 in) from the edge of the cylinder head as shown.
• Run bead, dimension "b", 20 mm (0.8 in) from edge of cylinder head as shown.
•Install the number 6 intake camshaft rear cap.
6.1. Tighten the cap bolts evenly to 5 N·m(44 lb in).
6.2. Tighten the cap bolts evenly to 10 N·m(89 lb in).
6.3. Back the cap bolts out 120 degrees.
6.4. Tighten the cap bolts evenly a final pass to 10 N·m(89 lb in).
•Install the camshaft cover and gasket, GM P/N 12609291. Refer to Camshaft Cover Installation in SI.
•Install the fuel pump. Refer to Fuel Pump Installation in SI.
Important: When installing the fuel pump, install a NEW high pressure fuel pump O-ring (GM P/N 12600313), high pressure fuel pump gasket-to-cylinder head (GM P/N12595951) and high pressure fuel pipe (GM P/N12615401).
Parts Information
Part Number
Description
12609291
Camshaft Cover Gasket
12595951
Gasket, High Pressure Fuel Pump Gasket
12600313
High Pressure Fuel Pump O-Ring
12615401
High Pressure Fuel Pipe
12378521 (U.S.)
88901148 (Canada)
Silicone
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J7549*
Reseal Camshaft Cap
2.6 hrs
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2010 General Motors. All rights reserved.
