Forge bypass valve
yes its worth it. Stock one is a rubber like unit and can tear and rip. It also can get stuck and not release right. Forge is all metal and controled with two different springs. Well worth the upgrade!
I've had mine since the initial group buy thanks to gdubs and it works great. I'm curious if people are lubing these things periodically and with what. I just installed it out of the box and havent touched it since- is it recommended to lubricate these things periodically?
I just did maintenence on my Forge BPV.
You lube it with Mobile 1 grease. The tube will last you forever. Clean it off and then just a small amount spread over the O-rings of the piston in the BPV is plenty. Do it maybe once or twice a year.
CEL is very easy to handle. If you have a smartphone you can buy bluetooth OBD-II scanner for 35 bucks on ebay and use android app torque to read and clear codes.
Or if you don't have a smartphone you can just get a regular OBD-II scanner for about the same price.
Anything other then Mobil 1 Synthetic grease, will F up the O-Rings. According to forge.
