GM Stage 1 Question
GM Stage 1 Question
I have the 3 bar map sensors that come with the stage tune. I have been have an issue where car goes into limp and will not boost more than 5psi. Think it is an issue with the connection on the lower map. I would just like to replace it with the newer plug and play connector that CED has now but im wondering cause I have the original ones that are spliced in can i do that or do I have to buy the original and resplice it?
If the original connectors have been cut off, the plug and play ones won't fit. So you'd have to replace the connector with another one. I have a couple of the AC Delco pigtails from the stage kit, but it's odd that the connector is an issue, have you checked the wiring? Possibly it wasn't soldered well or something that could be a quick fix with no parts needed.
ShagMeyer (08-30-2015)
ya it probably is where it is solder in at. I haven't checked it yet and im not sure i would know what im looking at and be able to tell if it was bad or not. I just would assume have the dealer replace the pigtail with a new one and have it freshly solder in.
is this the pigtail I would need to replace the lower map?ACDelco Pigtail PT 1863 88988320
