help turbo ss problem intake system issue
Old 06-09-2008 | 02:07 PM
TrevMo's Avatar
Originally Posted by krispy
The typhoon kit will not work
Thanks! If anyone can verify that the 2.2 K&N filter will work with the 2.0 SS/TC, I would greatly appreciate it!
Old 06-09-2008 | 02:41 PM
krispy's Avatar
I think you may have to be the one to verify it. You might be able to find that K&N filter at a local store (autozone/etc). Just go there and see if it will fit in, although be careful with the upper housing as there has already been one failure. [see top of this thread]
Old 06-09-2008 | 03:33 PM
TrevMo's Avatar
Have you already tried this filter in a SS/TC or are you just going off of what you know about these two engines? I plan on picking one up and giving it a shot...I'll let everyone know what I find out.
Old 06-09-2008 | 04:02 PM
krispy's Avatar
Just going off that the 2.0 and the 2.2 both have the same lower filter housing [same part number] (which the filter sits in, so basically they fit the same filters), so if a K&N fits the 2.2 it will fit the 2.0.
Old 06-09-2008 | 04:14 PM
TrevMo's Avatar
Thanks! I'll let you guys know! It might be a week or two until I get around to it, but I'll be sure to let all you SS/TC owners know!
Old 06-09-2008 | 11:17 PM
madlion's Avatar
33-2311 is the k&n filter that fits. go to autozone and ask if they have 2311 k&n filter. They will know exactly. Yeah everyone please learn something from my 40$ mistake. much thanks again to cobalt ss/tc for being informative instead of critisizing.
Old 06-25-2008 | 05:12 PM
madlion's Avatar
*update* i received the elbow and fixed the problem myself. My old repaired rig worked very well and didnt need replacing. infact you couldnt really tell it was broken. ill post pics soon!
Old 06-25-2008 | 05:22 PM
Tomtwtwtw's Avatar
Originally Posted by Cobaltss/TC
Ok this is from Service info from GM, i just wanted to inform people so this doesn't happen again, that breather hose is supposed to be removed from the intake while removing the air filter or working on the intake tube!!!!!!!!!!!!!!!!! it is a simple disconnect procedure.If you look at the pic it is the cream color tab that you press together to release tube.Hope this helps people out.
That info is also in the owner's manual when it talks about changing air filters. Read it, people!
Old 06-25-2008 | 10:50 PM
M1kl0's Avatar
that sux but what i would is figure out a "quick fix" most times it inclsudes electrical tape XD but if i were i would just wait till CAI that ttr is making comes out and install that on, that would be better
Old 06-26-2008 | 12:56 AM
madlion's Avatar
i am not a fan of most cold air intakes. i prefer short ram air intakes or maybe a form of cowl induction.
Old 06-28-2008 | 08:22 PM
  #36
sporttintturbo's Avatar
yes it works
Old 06-28-2008 | 08:28 PM
  #37
Tazmanian_Dvl's Avatar
Dealer
Old 04-11-2011 | 09:57 PM
  #38
Drichard's Avatar
sorry to bring such an old post to the top. I started a thread about this in another section, and then finally came across this thread in the search. Looks like my problem is identical to this one. Just wondering what this hose does? And what would happen if I was driving for a month or two with this broken?
Old 04-11-2011 | 10:42 PM
  #39
ronn's Avatar
Don't worry..won't hurt your car driving with it broken off. It's the PCV hose that recirculates blow by (exhaust and unburned gases that contain some oil vapors) from the crankcase back into the intake to be burned off.
Old 04-12-2011 | 02:07 AM
  #40
FRQ FLYR's Avatar
If you didn't seal up your intake your engine is taking in unmetered/unfiltered air I would think. Probably not good.
Happened to me too/warrantied.
Old 12-01-2011 | 05:09 AM
  #41
SS-Performance-RS's Avatar
Just to revive this thread again, can we delete this hose and run like some sort of push in filter or something?
Old 12-01-2011 | 08:38 AM
  #42
CudaJoe's Avatar
you could probably run a breather filter off of it. I've seen that done on alot of rice looking cars but it would work. Just plug the hole on the intake side.
The only downside I could imagine to using those little filters is an oil blow by is going to either clog up the filter or spew oil and grease onto your hood or across the engine.
Turbo Johnny
02-21-2019 10:41 AM
vjoel2011
10-02-2015 01:11 PM
Josh@ottp
09-08-2015 11:18 AM
jthwjde
09-07-2015 10:24 AM
CobaltSS 16
09-06-2015 03:04 PM
