Installing a pcm.
Old 12-04-2015 | 04:00 PM
ATOMbomb's Avatar
Installing a pcm.
So I purchased a tuned pcm. Long story short. I could not seem to find out how to swap the ecu on an lnf.
I noticed the sc and other cobalts do not have those little tabs I guess you can call them. Rather not screw up the pins. Lol
Does it just wiggle out like a typical plug or do I have to use the tabs on top to "unlock" it first.
Thanks css
Old 12-04-2015 | 04:17 PM
sixgear's Avatar
The Plugs are cam locked, there is a lever on the plugs that you pull up on which will lift your plugs off of the pins, go easy and slightly lift up on plug as you are lifting the lever, the PCM slips down in a cradle that has a tab on each side to lock it in.
It has plastic tabs on the top pull them to the opposite side becareful tho, the connector will start lifting after that. Don't forget to disconnect your battery first tho. You will probably have to do the relearn
Old 12-04-2015 | 08:57 PM
ATOMbomb's Avatar
Thanks. I know I'm looking forward to doing the relearn. I'm surprised zzp didn't mention a how swap since they already have the relearn.
Going to try and do it tomorrow since it will be in the 50s instead of the 40s. I know how brittle plastic is the colder it gets. Thanks again
Old 12-04-2015 | 11:05 PM
SR Tech's Avatar
For what it's worth, I've never disconnected the battery before swapping the PCM
Old 12-05-2015 | 03:51 PM
I've always disconnected it if I remember correctly, I usually just disconnect it and the take the pcm off within the same minute. But hey rather be safe than sorry but yeah you would maybe be fine without disconnecting it.
Old 12-06-2015 | 04:33 PM
ATOMbomb's Avatar
Finally was able to install it today. Fired up on the 4th time.
One thing I noticed. My oil life went from 98% to 84% when it started.. Could that just be the percentage that was on the pcm when it was sent to me since it was one of refurbished refundable ones.
Old 12-06-2015 | 06:24 PM
That could be it
Old 12-06-2015 | 08:13 PM
ATOMbomb's Avatar
That's the only thing I can think is possible.
Old 12-06-2015 | 08:48 PM
Wonder if the oil life is in the pcm or the bcm like the miles are on the bcm
Old 12-06-2015 | 09:08 PM
ATOMbomb's Avatar
Where is the mpg and trips saved too then? I would think it would be where the oil life is because all those are able to be reset. Idk lol. Hopefully some others chine in that may know.
Old 12-06-2015 | 09:13 PM
Mpg for sure is the pcm I get 25mpg on the other pcm I have and I'm at 30mpg on the original one
Old 12-06-2015 | 09:53 PM
ATOMbomb's Avatar
Wow that's a difference lol. Tunes on both or just one of them?
Old 12-06-2015 | 09:57 PM
Just on one the bad one is the stock tune lol
Old 12-06-2015 | 11:09 PM
ATOMbomb's Avatar
Go figure hahah.
Old 12-06-2015 | 11:22 PM
Hahaha yeah it's crazy the power difference tho I spin 2nd on the tune and stock it's just a chirp and go
Old 12-07-2015 | 01:18 AM
ATOMbomb's Avatar
You have a zzp tune or hp tuners?
Old 12-07-2015 | 01:37 AM
I'm hp tuned working on getting my own cable tho
Old 12-07-2015 | 02:08 AM
ATOMbomb's Avatar
Nice. What kind of numbers are you putting down? I will eventually get hptuners. Just wanted something for the damn cai.
Old 12-07-2015 | 11:16 AM
Not sure I haven't dynoed the car as of now but I will before I install my k04r
carfanatic15
11-16-2016 01:04 PM
GoodSpeed150
12-07-2015 02:28 PM
ae_xiong
Drag Racing
12-04-2015 11:47 PM
aebooth6
Tuning
12-03-2015 04:53 AM
jrsmith
11-29-2015 12:50 PM
