Lost all gears, could put in any gear without using clutch
Old 10-09-2015 | 10:47 PM
Jon Jessie Cremeans's Avatar
Ok I have a 09 Chevy cobalt ss manual what happened was all of a sudden I lost all gears I could go into every gear without even using the clutch this happened in May but the car wouldn't move at all and even in every gear it wouldn't engage at all but a few moments ago I started the car tried to push it into gear but it wouldn't work I actually had to use the clutch an what's weird is it actually engaged I was able to drive forward and go in reverse I didn't really drive it to not risk any further damage but what could be the issue?
Old 10-10-2015 | 12:20 AM
I had the same issue would up being that the passenger side axle stripped the spline inside the intermediate shaft. Check out your axles.
Old 10-11-2015 | 09:14 AM
QuickSilver_SS's Avatar
It could also be the roll pin.
Old 10-11-2015 | 09:43 AM
Maybe the cable clamp broke
Old 10-11-2015 | 11:03 AM
Squints's Avatar
This was my first thought
Old 10-11-2015 | 11:06 AM
T-fog's Avatar
^This, Friend did it the same thing right after he was racing/NLS lol
I thought the roll pin was no gear/won't go in gear kinda feeling.
Old 10-11-2015 | 02:33 PM
Yeah if you can feel it go into gear should be something axle related. If you can do that and it bogs down a bit too
SunburstSS
12-02-2015 09:25 PM
Jerin
10-20-2015 07:24 AM
GreenStang
10-18-2015 02:04 AM
Koalt45
10-12-2015 07:22 AM
dennis69
10-10-2015 08:57 AM
Quick Reply: Lost all gears, could put in any gear without using clutch
