Lost on the MAP
Old 06-17-2015 | 10:59 PM
Grimor's Avatar
Lost on the MAP
So, I have read a bunch about the MAP sensors on the site and other places. I'm still pretty confused about what I need to do.
First, I need to replace my MAP sensor. Previously I got the MAP BARO code only when the weather was muggy and it was about to rain. I got a tune (HP Tuners) and am running 23psi boost. Since then I have been getting the code more frequently.
I have read that the stock sensor is only good to 21psi and that there is a 4 wire sensor but not sure if it's needed. If I will need to change the tune if I do get one, and how I would even wire it. Any links or information would be appreciated.
2010 LNF TC SS
EDIT:
Instructions for 4 wire MAP http://www.crateenginedepot.com/pdfs/frsp19212711.pdf
MAP sensor: http://www.crateenginedepot.com/3-Ba...97-P10930.aspx
Plug: http://www.bmotorsports.com/shop/pro...oducts_id/1626
Reading this thread: https://www.cobaltss.net/forums/2-0l...ensors-244938/ I haven't figured out what psi is the max on stock sensors.
Old 06-17-2015 | 11:32 PM
Sl0wbaltSS's Avatar
just get the 3 bar set from zzp with the connectors. not the ones you have to sodder.
Old 06-18-2015 | 12:33 AM
Psykostevo's Avatar
Definitely only get the plug and play ones. And of course change your MAP sensor settings in the tune and other necessary table changes too.
Old 06-18-2015 | 05:49 PM
Grimor's Avatar
That was my main concern, what would the effect be going with the new sensors and needing to wait for the tune? The sensors already throw a code so would it be any different?
Old 06-18-2015 | 06:05 PM
Sl0wbaltSS's Avatar
Well, if you put the sensors in without a tune, you're going to get a code and only boost 5 psi.
Old 06-21-2015 | 02:50 AM
brycerice13's Avatar
I could be wrong so if anyone knows please correct me, but the Map Baro sensor should be measuring barometric pressure as a baseline that it needs to subtract to reach the desired boost level. So I think that is a different sensor then the MAP sensor on the intake manifold or the MAP sensor on the lower charge pipe. I believe that sensor only measures outside atmospheric pressure.
Old 06-23-2015 | 03:16 PM
Grimor's Avatar
I have no idea, I thought the baro was on the MAP. I'll pull the exact code again and see what I can track down.
DarrenGC
12-24-2021 02:55 PM
RaginChopsuey
10-27-2015 02:27 PM
MrInsanityWolf
09-29-2015 05:54 PM
anotherslowlnf
09-29-2015 04:52 PM
Adiaz1ss
09-27-2015 12:51 AM
