My "Buy a LNF they said..." Problem/Build Thread.
#226
Thread hijack:
Where'd you pick your STi up from? I see you live in Colorado; Heuberger?
I ordered mine through them and got a bomb ass deal on it. Even shipping it to my front door I saved thousands over local pricing.
#229
Haven't bought it yet. Still demodding the Cobalt and selling all the aftermarket parts. We bought our 2014 Wrx from Groove Subaru
#231
RECALLED
Buuuuttttt Florida only lets you have 7 characters and one space in addition to that. Cant have 8 though.
I wanted to go with NOW STFU, but my gf and coworkers kept saying how I needed to be more adult about it because of my job lol.
#233
Can't catch a break on this; new ZZP issue is that the MAF relocation harness I bought from them is falling apart. Car now displays MAF Sensor Low Voltage codes.
Fired and email with pics off to ZZP about it, hopefully they expedite me a new one seeing as I only used this one, for one week, with their LCP and its coming apart on its own.
#234
I never liked the placement of the MAF relocate on the LNF. Makes no sense to have the maf sensor plug facing the fans. It's a tight squeeze and unfortunately it resulted in pinched wires for you.
I never understood why the MAF relocate couldn't be turned 90 degrees to either side so the plug faces either the driver or passenger side of the vehicle. Then you can take the sensor out without having to rip the whole pipe out.
You'd think R&D would reveal these simple problems. But I'm guessing most companies just go with the &D portion of that equation. Especially on these cars. Hell, GM couldn't have found a more idiotic place to put the oil filter.
#235
Oh ok. Well check out Heuberger if you haven't before. They are the largest volume dealership for Subarus in the US so great deals can be had because they aren't worried about front end profit. They make money on back end and manufacture incentives for units sold.
#236
#237
LSJ is a bastard
#238
L61 and LAP don't have anything obstructing them.
They looked pinched. In any event, still a crappy design.
#242
#244
Even when I clear them they all come back.
I am replacing the ZZP MAF extention harness because it had a couple loose wires that I believe is causing the MAF code. The car never had these codes prior to the clutch job I did. When I bought it I data logged the car and checked all of the codes; it was problem free in that aspect.
#245
I will say of all the parts I bought on my car
the ZZP lower charge pipe was the biggest piece of ****, which is pretty sad considering I have a Treadstone FMIC which was made for a damn DSM.
I actually cut it so it could go in two pieces, it makes putting it together 10x easier
my MAF relocation plug bolt holes were not drilled the same.
The Vacuum nipple bolt they gave me didn't fit either.
#246
I am writing josh at OTTP an email and citing a lot of the complaints about this ZZP one. I think if he makes his lower charge pipe the way I cut mine and moves the MAF 90 degrees so you can change it without pulling out the pipe they will fly off of the shelves. Especially is he under cuts ZZP and has the better and easier to install and use product.
Hopefully he can work something out because I will be the first one to buy it!
#247
#249
All MAF related I guarantee. But, if the MAF extension gets replaced and codes persist, well then it may be because of these things:
System too lean at idle and your other too lean code should be able to be cleared up through additional tuning. I had the same issue when I was first tuning for the atmospherical BOV.
O2 sensor looks like it'll need to be replaced unless your downpipe doesn't have an angled bung... That may be the issue there.
