My "Buy a LNF they said..." Problem/Build Thread.
#376
That is the issue I am running into. I think it is the cause of some of the knock too. Between the ZZP LC tapping and the HAHN hitting, I think that is where all of the random knock is coming from.
Thing about that is that we will end up with a lot of clamps and couplers at that point.
#378
They dont include a vacuum nipple or anything so your BPV/BOV will stay open. It fit like ****, and they didn't drill the MAP Sensor hole correctly which in turn caused a massive boost leak. I returned their ****.
#380
I am moving the MAF to the intake today and seeing if anything changes.
I am also sating to wonder if maybe some of the passages inside the IC are dirty and possibly causing turbulence?
Maybe the wastegate actuator is bad causing the wastegate to fluctuate sending pulses?
#381
#382
I wouldnt see the dirty ic passages causing turbulence that far away. If the airflow jumps quickly its something else, hopefully the previous guy who tune the balt didnt mess with the OT and OS tables not sure if they would cause that really high reading all of a sudden though
#384
I had the IC off. It had water in it, but I cleaned it all out. Water was likely from the car sitting for 6 weeks with an open IC.
Does anyone have a MAF wiring diagram?
I want to find the pins on the ECU that go to the MAF. Connect a 9v battery to the wire and multimeter the other end. Make sure the voltage is the same or find a break if there is one.
#390
I mean when I see some one pulling out and the accident is 100% not going to be my fault; I don't slow down or anything...
The biggest issue is the inconsistency of it. When I came home Sunday night I drove two hours, boosted, and beat the car. It was flawless. This morning, hesitation, knock, maf issues. On my way home, ran fine. There has to be a maf issue in the connector or wiring. I'm moving the MAF back to the intake and flashing on a new tune. I doubt it will change anything, but it will further confirm it's wiring or PCM related. I may need a new PCM to try for a few days to see if the issues stop if the wires are fine.
Ps. Anyone ever open the wire loom on a LNF? Why is stuff heat shrunk from the factory?
#399
The connector stuff should be here somewhere.
http://www.bmotorsports.com/shop/ind.../cPath/109_136
Here it is
http://www.bmotorsports.com/shop/pro...oducts_id/1625
Now that you posted those pictures, I do remember seeing that. They must use that to cover a splice or to join multiple wires.
#400
Made a thread for some screen shots I would like here:
https://www.cobaltss.net/forums/tuni...e-here-315463/
I did what 1Panel2nv suggested and could not get any fluctuation in the MAF signal. Moved the wires every which was I could, pulled, yanked, etc. I took a snapshot of my VCM scanner. Car is off, key is ON, and log started. Can anyone else that has a MAF relocate do the same thing and post it up? I am curious to see if there is anything different in mine.
Another thing that happened is the battery died while I was doing this; like 5 minutes in. Pretty sure it has some bad cells. Getting it tested after work. I have seen bad batteries cause all sorts of weird issues in cars that use 5v references so maybe my issue surfaced there?
Also, I noticed that my WBo2 takes about 60 seconds to start metering. During the heat up time the car runs like **** now. Once it starts working everything it reads is very lean. My old WBo2 would heat up in about 15 seconds. Sensor on its way out?
I also pulled the manifold MAP and it had the blue o-ring on it. Replaced it with the correct black one.
