My "Buy a LNF they said..." Problem/Build Thread.
#52
Had a cobalt in the garage since 05. Been an amazing car quality wise. Of course you buy a modded LNF you get what you get.
Mandatory on the SS/SC along with rotated mounts.
Last edited by SuperchargedSS; 12-06-2014 at 07:00 PM. Reason: Automerged Doublepost
#54
I will take a closer look.
I am not impressed with the Hahn stuff.
My CAI is steel and the underside of it was all covered in rust. Inside is clean, but I will be replacing this at some point. Pretty shitty part if it spends its short life in FLA and is covered in rust.
#56
Thoughts on tires.
I have 18x8 +35mm wheels wrapped in 235/40/18 Nitto NT555r's. Two of them are shot (lol FWD burnouts). Anyways, I was thinking of putting a really aggressive tire on them and chucking them on the front. Thoughts? Recommendations? It would still be a daily tire so is it even worth it?
#57
Thoughts on tires.
#63
As long as the mounts are rotated and have quality bushings you should be fine. I have a powell front and an ottp rear with a powell insert, debating about getting a zzp upper engine mount when I swap turbos. I've had the zzp engine mount before waaaaay back before rotated mounts and it helped some with hop, but the vibes were craaaaaazy. Currently, I have balance shaft deletes with solid front/rear mounts so it's already kinda vibe friendly but just want the most stability when pushing the car that hard with the swap so we'll see.
#69
KY sent my clutch. It will be here Wednesday.
Only part left is my knuckle from Mongo.
Will be driving this car next week.
Possible buyer for my 06 SS.
He has 4k to put down. Anyone know where I should direct him to get a 3500 loan on it. Banks wont do it because of the age of the car.
#75
not at all
ftr my setup is powell s2 mounts (you lnf guys need s1) lnf rear mount and new engine mounts, no wheel hop
x2 on this my friends 430whp lnf allmost hooks in high 2nd
how much did ky charge for the clutch again? 400ish?
