Question about ss/tc clutch
clutch and flywheel shouldn't make any difference in a NLS... unless the lighter flywheel is allowing the revs to hit the limiter sooner instead of being able to "catch" it and hold it below redline?
When you say "can't", what exactly is happening when you try an NLS? Are you getting locked out of the next gear? Are you grinding? Are you just not getting the exhaust pop?....
I've heard that some people with aftermarket clutches haven't been able to NLS due to the new clutch friction point of the clutch pedal...
I think that the reason is because it is hiting the redline to fast and it doesn't give me a chance to change gear, but I would really like to see more opinion on what I can do and how to. I will try do to the nls in lower rpm and see what happen.
ItIsFast can you do the nls with the exedy clutch?
This is what you need: http://www.zzperformance.com/cobalt_...1096&catid=146
