Revised Fresh Air Tube (connects to air intake tube) slices through O-ring
Old 05-26-2016 | 06:15 PM
metroplex's Avatar
I bought the revised fresh air tube (the one that connects between the camcover and air intake tube) and the very first attempt to connect it to the nipple on the air intake hose, the nipple cuts the O-ring. The revised tube, to me, isn't as good of a design as the original because there's no way to rotate the plastic portion that connects to the nipple. It only goes in 1 way basically, and the nipple happened to slice right through that O-ring.
Does anyone happen to know the specs of that O-ring? It looks like I can replace it by removing the plastic clip. Otherwise, I'm basically out $35.
FWIW I am running the K&N SRI, and never had a real issue with the original tube other than it seemed like a tight fit. The revised tube changes the angles a bit, but it is also a tight fit, just in a different area.
Old 05-26-2016 | 06:55 PM
blueLNFftw's Avatar
Who makes this?
Old 05-26-2016 | 06:59 PM
metroplex's Avatar
It's a GM part.
I found my answer, Viton 904 O-rings 75A durometer. I was able to pull the bad O-ring out with a needle. Installing the new O-ring shouldn't be too bad.
Old 05-26-2016 | 10:06 PM
Tdubbs's Avatar
Originally Posted by blueLNFftw
Who makes this?
I believe he is refrering to this:
Engine Crankcase Ventilation Tube 12612790 12635643
GM updated the design, but personally the original design works quite well with the ZZP upgraded air tube, so I haven't bothered with it.
Old 05-29-2016 | 02:48 PM
metroplex's Avatar
I tried again to install the updated design, but it is a very very tight fit to the point it won't go onto the nipple. The old design slips right on with the same sized O-ring. GM must have changed the dimensions or something. They also just used heat shield wrapping around a rubber hose, instead of a SS braised hose. Bottom line is that I don't recommend the updated design.
Old 05-29-2016 | 06:15 PM
Solaris99's Avatar
I think the updated tube is only good if you have a stock intake boot and need to take stress off that nipple. If you have a silicone boot, the nipple can handle the braided hose tension.
Old 05-29-2016 | 08:08 PM
metroplex's Avatar
I think I understand that now. I'm running the K&N SRI which has its own polymer nipple fitting that seems to be easily replaced with something like brass or another K&N fitting if it ever breaks.
northvibe
06-06-2016 05:40 PM
2000Firehawk
05-25-2016 07:25 PM
Spacek SS
05-24-2016 07:05 PM
ProfDNS
Wheels and Tires
05-23-2016 12:31 AM
metroplex
05-21-2016 06:50 PM
Quick Reply: Revised Fresh Air Tube (connects to air intake tube) slices through O-ring
