Top speed in each gear
Second goes a little higher than 62 on the stock tune. If I NLS into third I'm hitting 70mph easily. I realize the car will coast to a higher speed even during the shift, but I'd wager I leave second at probably 65+mph.
This is for stock tires and stock redline:
1st gear - 36
2nd gear - 69
3rd gear - 103
4th gear - 136
5th gear - 173
Like it was mentioned, you have to watch out because the speedometer lags alot in low gears.
1st gear - 36
2nd gear - 69
3rd gear - 103
4th gear - 136
5th gear - 173
EDIT: Sorry guys, I fixed the spreadsheet for the correct tire size:
EDIT 2: See 2nd post.
I guess I kind of worded that wrong. I was just wondering the actual speeds. I know that the tach is the important part.
That spreadsheet is wrong.
The F35 MU3 in the 2008 and up cobalt SS with LNF has a 3.82 final drive not 4.05 which is the LSJ final drive. Also, the LNF stock redline is 6250 RPM.
I made the spreadsheet as a tool to see the relationship between rpm and mph for different combinations of tire size, final ratio, and trans ratios. I only got my cobalt a few days ago so I have yet to learn all the differences between models. If anyone wants to play with a copy of the spreadsheet, I can email it (since I can't post .xls files).
2008-2009 Cobalt SS Transmission Specs are:
GEAR/RATIO/OVERALL/(RPM)MPH
1st,:1 - 3.38/12.91/(6300)36 mph
2nd,:1 - 1.76/6.72/(6300)69 mph
3rd,:1 - 1.18/4.51/(6300)103 mph
4th,:1 - 0.89/3.40/(6300)137 mph
5th,:1 - 0.70/2.67/ est(5800)160 mph
Final Drive Ratio 3.82:1
this is with the stock lsj trans left and the lnf trans+ raised rpm right
http://www.fatboyraceworks.com/gears...raph&Compare=1
what mine will be with 7350 rev limit: but i will prolly shift at 7500-7600
1st Gear : 42.91MPH
2nd Gear : 82.42MPH
3rd Gear : 122.92MPH
4th Gear : 162.98MPH
5th Gear : 207.22MPH
1st Gear : 42.91MPH
2nd Gear : 82.42MPH
ThoR294
10-04-2015 08:44 PM
