Turbo Upgrade
Turbo Upgrade
Im not sure if this is where i should post this but as the title says i am going to upgrade my stock turbo to the zfr turbo. I have tried searching and havent found a solid answer to my questions which are 1) How much power can the stock engine handle ive heard from 400 600 hp. 2) I have all the basic bolt ons and zzp tune and clutch masters stage 1 clutch(stock clutch was burning) what else do i need to get for the new turbo(ex. Valve springs cams pistons) if the stock internals cant handle the bigger turbo? Im extremely tired and probably forgot something but any help is appreciated thank you.
Yep I learned the hard way when my 3rd gear jumped out while having some fun on the road. And I was just fully bolted n tuned on a pretty nasty street tune
I plan on getting a brand new stage 1 PerformanceAutowerks f35 transmission rated up to 400 whp 400 tq with a stage 3 clutch abrand new oem flywheel from zzp you think ill be good if I stay around 400hp 400 tq around 25 psi of boost
off topic but my idle is really rough on a cold start and matt from zzp double checked my tune file for my mods everything is good it started after I installed Hahn intake, could it just be normal from aftermarket intake or vacuum leak, dirty throttle body???? thanks everyone
I'm pretty sure u just opened a can of worms when u mentioned performance autowerks
I would recommend you spend just a little more money at werks and at least get the 4.05 gears or buy them from a member. 4.45 hears are the best for longevity of the trans but they are expensive and hard to find. Talk to Mongorat on here that's where I got mine. They help the trans to handle the torque better.
Tom77- why is it opening a can to talk about werks? That's where I had planned to do my trans also. Would gladly go with Powell but shipping the trans back and forth was too expensive. Even though Matt doesn't work there anymore he still gave them a thumbs up for doing the trans.
Gugi96 (10-19-2015)
