weird things on my cobalt
Old 04-30-2016 | 11:22 PM
turbolyfe501's Avatar
Since I've moved to Texas my cobalt hasn't peaked or gotten anywhere close to 15lbs of boost. Now here's what I did changed the oil and was going to just put the stock replacement filter but wanted to be cheap and brought the specter air filter from oreilys problem was no where to put the maf so I moved it to behind the air filter car would stay started so immediately figured that had to be it unplugged it the car idled high for a minute or two than settled drove it sound better than it has got on the highway did a 3rd gear pull top of 3rd 15.7lbs 4th peaked at 18.5 so my question is how is how is it possible and will running it without the maf hurt it
Old 04-30-2016 | 11:27 PM
blueLNFftw's Avatar
You need to install the maf sensor.
Old 04-30-2016 | 11:36 PM
Why when I moved it back the car back fires n wants to shut off??
Old 04-30-2016 | 11:53 PM
I've I know there a tune involved but with doing anything with the CAI and it will be easier to do a k&n filter but I like hearing the turbo noise lol
Old 05-01-2016 | 10:59 AM
Solaris99's Avatar
When you run a car without the MAF sensor, the computer uses fuel maps for assumed air values. This means it won't be able to adjust for any real changes, and you run the risk of running lean or rich. Disconnecting the MAF sensor should only be used as a troubleshooting step, not as a solution.
Old 05-01-2016 | 03:37 PM
blueLNFftw's Avatar
So fix the issue with the car.
The LNF cannot run speed density. The car is running on the most basic tables and should not be left this way. You are asking for a blown motor.
Old 05-01-2016 | 05:01 PM
Yea that's what I figured haven't drove it. Would a tune fix it because it run with the maf plugged in but it backfiring and coughing my hope is getting it tuned will fix it idk
Old 05-01-2016 | 05:33 PM
Solaris99's Avatar
I would first put the intake back to the way it was to confirm the intake change was the cause.
Old 05-01-2016 | 07:39 PM
Put everything back to stock just upgraded to a k&n air filter starts but runs like crap never smooths out
Old 05-01-2016 | 09:02 PM
Solaris99's Avatar
Try disconnecting the battery to clear adaptations.
Old 05-01-2016 | 10:29 PM
Thanks guys ill let all know the outcome trying to get a tune tonight
Old 05-02-2016 | 02:32 AM
firehawk618's Avatar
Your OP has fail written all over it.
Put it all back to stock until you can do things the right way.
You fool around with the pre turbo intake system you MUST have a tune written for it.
Period.
Old 05-02-2016 | 11:35 AM
Period.
That what I did waiting to get it tuned before I try anything else
dougl122
03-07-2016 08:08 PM
xRedrumisBack
Tuning
02-23-2016 01:06 AM
Tomcat801
02-17-2016 04:47 PM
ttrawicki1
02-11-2016 07:36 PM
jcalvin1126
02-07-2016 09:50 AM
