ZFR overboost
ZFR overboost
So, I bought and installed a ZFR 6758 and for the last couple weeks have been trying to find out why it is over boosting so bad. No matter the tune, the turbo always goes to 30 pounds of boost! I was wondering if it could be the waste gate, bpv, vacuum lines or what? I don't have any pictures currently but have no problem running out to the car and taking the pictures for you guys.
Mods
Zfr6758
ZZP upper charge pipe
Treadstone tr-12 intercooler
3-bar map
ky stage 3
turbo xs fl catback
zzp catless downpipe
powell stage 1 mounts
AEM CAI
Mods
Zfr6758
3-bar map
ky stage 3
turbo xs fl catback
AEM CAI
What is based off airflow? If you're talking about the ECU it's based on torque, and if the car is dropping the desired boost and the boost isn't dropping it means the wastegate isn't opening enough.
OP - There's either an issue with your waste gate, or your tuner. If you're running the high boost wg can, they can at times be tough to control at first. Have your tuner go SUPER conservative on wgdc settings to start and work your way up slowly.
nathan112i (11-15-2015)
Well, I'll get him on the conversation tomorrow. But as of right now I was thinking that it may be the boost canister because of that linked thread. But I can always upload logs for you guys to look at.
All of which will be blasted by desired targets (short of wgdc) if prop gain and wgdc are set too aggressively with the high boost can. All the other tables will do is force the car into limp mode due to an overboost condition. Only way around it is to set the overboost limits through the roof and subsequently watch boost launch to the moon. Seen it happen in some questionable tunes unfortunately. Some of which were boosting far more than the 31psi limits of the 3bar maps and flat lining them at 31psi in the graphs.
Rent me! per hour
there is a couple in there that are hardset limits and start the calculations for the others. One table noticeably is way too over looked by people. the one little table that makes 20+ psi capable at redline on a stock k04.
LNF, full bolt ons, catless dp, k04 holding over 20psi to 6500+ rpm? Excuse the skepticism but that's a pretty tough pill to swallow. I've made it happen with lnf's in otherwise stock form, but with full bolt ons.... meh idk. That's quite a bit to ask of that little guy. It's kind of a flow limitation thing we're talking here, not so much a tune thing. Ya know?
Rent me! per hour
Say your setting a max of 270 kps to more or less get away from the codes, but you have a max factor of 3.0 and your target is 24 psi. guess what just happened. you just over shot the target by 3.9 psi. this is causing the wastegate to double its duty and slam shut and open back up causing more work on the solenoid itself. All with in a split second.
At 6300 i see an average of 21-22 psi with a commanded peak of 24 psi. it's not rocket science, people just don't understand the tables and how they work together for their own personal benefit.
I do understand the flow limitation of an object spinning at 100k rpms. Which is why i rarely go past 6100-6200 rpms on a stock turbo/stock cams as all you're doing is pissing it off and wasting time.
yes, i would start by backing the nuts off so you can move the WG by hand. move the WG all the way to the closed position and tighten the nut finger tight, turn the preload nut 3-4 more times then tighten the jam nut on the other side. that will give you a baseline to start from
XStylus
10-23-2015 03:52 PM
