2010 LNF issues
2010 LNF issues
Hey guys bear with me on this cause this is my second time posting here but I really need help, I have a 2010 LNF and it just started to give me some issues, while driving I can hear the BPV constantly letting off boost and the car bucks and jerks around something fierce! It's un driveable! I put a aftermarket BPV in hoping that would work but it did nothing, I also changed the BPV solenoid that all the lines are connected to and still nothing, I disconnected the battery for a while and still no change! No check engine light or nothing, it completely bolted with a ZZP PCM, I put the stock PCM thinking maybe something with the tune but same result! Any ideas wtf is going on? It's my daily so I need it for work, thanks for your time and patience.
no unfortunately it does it every gear even at low speed, I mean in first gear it jerks so hard I can't even drive it, it's almost worse at lower rpm's, I never changed anything, it just stared to happen a coupe days ago for no apparent reason
I should correct that when I say the BPV is constantly letting off boost it still has a very quick moment that it lets a tiny bit of boost build for maybe a second, not even enough to register the boost on the RPD, but then instantly lets it off and I can hear the BPV slightly whistle, Thanks again for your guys time!
your description is too vague.
Describe more precisely what the car is doing, what gear, rpm, throttle position, manifold pressure (if you have a gauge) i'd ask for a data log if you have the means.
describe your setup, all mods, how are your vacuum lines routed, i've seen some odd stuff with routing on this site.
if the car was not stock when you bought it, you might as well take a picture of how all the vacuum tubes are routed, just to establish a baseline here.
Then we can start talking.
Keep running your stock ECU, then read codes, EVEN with no check engine light, read codes, not all codes set the check engine light. I say keep the stock ECU because you dont know which codes were changed or turned off in the aftermarket tune.
^^^This and Also take picture of you bpv you could have ordered wrong like me and got a BOV lol
Also is this new or used? Is all the rubber o rings/seals there? If it is used did you lube the piston?
your description is too vague. Describe more precisely what the car is doing, what gear, rpm, throttle position, manifold pressure (if you have a gauge) i'd ask for a data log if you have the means. describe your setup, all mods, how are your vacuum lines routed, i've seen some odd stuff with routing on this site. if the car was not stock when you bought it, you might as well take a picture of how all the vacuum tubes are routed, just to establish a baseline here. Then we can start talking. Keep running your stock ECU, then read codes, EVEN with no check engine light, read codes, not all codes set the check engine light. I say keep the stock ECU because you dont know which codes were changed or turned off in the aftermarket tune.
I had the stock one in at the time the problem started, I switched to the forged one which is the same as stock one it does not vent to air I'm 100% sure it's the correct one, but that still didn't change the issue so I don't think it's the BPV itself
Most obvious first step, LIKE YOU SAID, please fix those MAP wires, and do it right. If you're not mechanically inclined, not used to soldering in an automotive environment, find someone to help. Hell, post your location on here, someone might be willing to help, if ur somewhere around detroit i'll log ur car and solder them right.
Although it never happened to me i have seen some threads where the MAP sensor itself fails, that might also be your problem. (although that's just a guess).
It could be a LOT of things, i'd rather not just start guessing, the list is too long. Autozone/Advanced auto/Oreiley's will read codes for you for free, write down the codes they read out, ignore their recommendations, and come post the codes here.
Your details helped, thanks for that. First things first, fix the wiring on BOTH those MAP sensors, and we'll go from there. The parts list you stated seems like quality parts, i'm surprised you dont have codes, at least the cat performance code or something.
Most obvious first step, LIKE YOU SAID, please fix those MAP wires, and do it right. If you're not mechanically inclined, not used to soldering in an automotive environment, find someone to help. Hell, post your location on here, someone might be willing to help, if ur somewhere around detroit i'll log ur car and solder them right. Although it never happened to me i have seen some threads where the MAP sensor itself fails, that might also be your problem. (although that's just a guess). It could be a LOT of things, i'd rather not just start guessing, the list is too long. Autozone/Advanced auto/Oreiley's will read codes for you for free, write down the codes they read out, ignore their recommendations, and come post the codes here. Your details helped, thanks for that. First things first, fix the wiring on BOTH those MAP sensors, and we'll go from there. The parts list you stated seems like quality parts, i'm surprised you dont have codes, at least the cat performance code or something.
I replaced the solenoid so I know it's not that and the tank delete has been done for a while now. I did mess with those map wires even more though and stretched them out, and took the car for a spin and it ran perfect, not one issue! So it has to be the shitty wiring job, I'm just gonna get it fixed and go from there but I'm 99.9% sure that's the issue.
rs-qt
10-24-2015 06:30 AM
rs-qt
10-05-2015 09:53 AM
