500whp LNF sleeper
Old 09-19-2016 | 08:23 PM
  #76
63 Nova SS's Avatar
Well, yeah, I get that, but don't most cars just use 1 2 and 3, regardless of transmission setup in the quarter? I have no experience there. At the road track you want to use 2 3 and 4 and not have to get into 5. I was close to redlining on the straight in 4th @140 even with the F35 before I upgraded my top end so I could rev to 8K+...
Op sorry to hijack your thread but it's info that's useful too you-
3rd gear with the 3.82 gears I hit redline (7,200) about 40ft from the lights and started slowing down, but still trapped 115 due to not shifting into 4th and losing speed doing it. That was shifting at about 7,000 every gear which is a waste for my power.
With the 4.45's I'm at about 6200 in 4th gear going through the lights at about 112-113. I would have to rev to like 8,300 in 3rd to run it out without shifting. And we know that ain't happening. 1st gear is a bear to not spin off the line unless you have slicks. My drag radials won't even hold it. Slicks will.
Old 09-20-2016 | 10:48 AM
  #77
tomj77's Avatar
Originally Posted by KMO43
I have a gen3
I know but zzp says if ur planning on doing 600 plus u need the girdled block or ull crack cylinders possibly
Old 09-20-2016 | 11:41 AM
  #78
KMO43's Avatar
Do you think maybe they wanna sell their girdled block which is $1000 more?
Old 09-20-2016 | 01:24 PM
  #79
tomj77's Avatar
Guess ull find out eh
Old 09-21-2016 | 11:59 AM
  #80
Scythe_Snake's Avatar
YOU will DEFINITELY need a girdled block with going for 600 lol
Ask me how I know. Personal experience, a Gen 3 block will handle 500+....for a little bit. And then your car will force you to upgrade it. :-)
As for the 6 speed, after having 3 our of the 4 transmission options in my car before I started working at ZZP (3.82, 4.45, and F40), there is no comparison. The recommended F40 blows the other two out of the water.
Definitely not slower around the track either (road racing or straightline). The F40s 1st gear isn't as usable as the 3.82s, but not quite as bad as the 4.45, the rest of the gearing has been by far the favorite out of all the transmissions.
Had a non LSD 4.05 in my LSJ though.
Old 09-21-2016 | 12:13 PM
  #81
KMO43's Avatar
Im only gonna turn it up to see what it'll do with the 71 after the dyno I'll be running it at a sane level
  #82
user 72239's Avatar
yeah, after having my STi with a 6 speed if I still had a Cobalt I'd run an F40 in a heartbeat.
Old 09-21-2016 | 01:26 PM
  #83
tomj77's Avatar
Would 500whp be reliable with non girdled block. Or is that just an upgrade waiting to happen as well?
Old 09-21-2016 | 01:27 PM
  #84
Right at it would likely be fine. All depends on how much you beat on it and the like.
Old 09-21-2016 | 02:00 PM
  #85
KMO43's Avatar
I ran my stock block at over 500 and its fine
Old 09-21-2016 | 06:10 PM
  #86
I also ran mine there....for a decent while, but it is a disaster waiting to happen. I prefer to nip things in the bud, personally.
Wouldn't recommend it. Gen 2's are known to be ticking time bombs past 450.
Old 10-09-2016 | 04:28 PM
  #87
Canadia's Avatar
In the 3s. I'd have to look I did all my tuning in 4th. With 4.45s justin did 3.5 with less hp than me
What's your 75-100? Compared to Shaun's 2.9
Old 10-09-2016 | 05:27 PM
  #88
KMO43's Avatar
IDK I only did 90 to 130s this year on low boost
Hill1513
10-27-2016 05:55 AM
ThePanduuh
10-18-2016 04:54 PM
lsjunior
08-28-2016 03:56 PM
Scypheroth
08-19-2016 01:37 AM
Livethatlife
08-15-2016 02:28 PM
Quick Reply: 500whp LNF sleeper
