balancing shaft timing mark question
Old 03-05-2015 | 08:58 PM
BaltNasty's Avatar
I'm putting in a balancing shaft/water pump chain. I lined up the the timing marks, and turned the engine over to make sure the markers would come back to the right spot. I turned it 3 full rotations of the chain, and each timing marker was off by 1 chain link. I turned it 3 more full rotations, and the markers where off by 2 chain links. Is this the way the balancing shaft chain is designed to work on these cars?
Old 03-05-2015 | 09:15 PM
kzak104's Avatar
link colors are for initial timing, they wont line up after many revolutions.
Old 03-05-2015 | 09:16 PM
cleanxfe's Avatar
As long as you have the marks lined up when you set it up your fine the gears are different sizes so it will not line up if you rotate the engine
Old 03-05-2015 | 09:17 PM
cleanxfe's Avatar
Again you beat me to it lol
Old 03-05-2015 | 09:21 PM
BaltNasty's Avatar
Thanks. I'm used to dealing with a timing belt with only a drive, and one cam so when you rotate it a few time it syncs up again.
Old 03-05-2015 | 11:29 PM
kzak104's Avatar
those marks are on the cam gear and crank gear, not the belt itself, you could mark the balance shaft gear and put a mark just behind it, rotate and make sure they line up, cant be to careful when timing.
bigdeertz
11-17-2016 10:41 AM
brandon04
10-21-2015 08:04 AM
09-27-2015 09:53 PM
jrocstar
09-27-2015 12:42 AM
roth
09-26-2015 01:16 PM
