Best recommendation for simple tune for non enthusiast?
Hey guys,
Ran into an older guy with an auto HHR SS yesterday and scared the **** out of him with my car! Since auto's stock tune is 235hp.... He said what do I have to do!
He's older, not the type to seek out a tuner or mod the car. So what is the best option for an easy plug and play tune on a stock vehicle (will recommend a downpipe but he probably wont)
I was thinking ZZP PCM maybe? Don't think hed be the type to seek out a tuner.
Thanks
Thanks
But in terms of how would you get it? Then you need 3 bar maps? I think a 22PSI ZZP ECM would probably be the easiest since it is tweaked better than GM with HPtuners. Am I right?
GMS1 tune hands down the best option.
19212670 Cobalt, Solstice, HHR Stage Kit 19212670
Just get the kit and go to a dealer, or someone with a tech 2.
I'm old, and I'm rocking full boltons, ko4+ and e47. Had faster cars most my life though. Agree that the gms kit will be fun for him over stock and won't be a hassle if he needs the dealer to work on it. Make sure he gets the premade splice kit for the maps, easy install and no worries.
northvibe (10-12-2015)
stock turbo E85, 1.6 60ft runs a 12.3
3300lbs Auto HHR
LS brake swap 15'' light enkeis/slicks
ZERO ramp (obviously) crazy 2nd gear overboost (forget what he said the PSI was)
2600rpm Boost launch
112 trap speed
Only performance mods were intake, punched out second cat and 3" exhaust.
3300lbs Auto HHR
112 trap speed
3300lbs Auto HHR
112 trap speed
3300lbs Auto HHR
112 trap speed
Furthermore, I would recommend the GMTU to this non-enthusiast. NOT GM stage 1 since there is no such thing for the LNF
they are the same thing, just easier to call it gms1. For simplicity Id recommend the gm tune.
cost a lil more and wont be as much power as custom but unless they have decent knowledge of the car id stick to simple gms1 with some good bolt ons maybe. That way if any work needs to be done they can take it to the dealer and not worry as much.
f custom. If you drive year round and go too aggressive on the custom tune you will run like @#$@# in the winter vs summer etc. gms1 is a great tune all year round, no f'ing with ****. just put 91 or higher in and have a blast. Also as an old guy, unless they are super into it, it isn't worth having to deal with the BS of retuning etc. especially if it is a DD.
I have custom tune and drive all year long with no problems, i know winter inst as harsh here in texas but still im able to drive its all in the tune. if the guy isnt an enthusiast like the op mentioned why go aggressive on the tune? Any tune should be fine custom, zzp or gms1(GMTU as some mentioned)
Are you including wind chill with that? If not, thats cold as hell. Weve seen -30 with windchill here in MI. Nothing works at that point. The starter on my jeep froze last winter.
