boost issue underboost ?
I posted a thread yesterday. The response I got was that I may have a boost leak. I'm not convinced that is the problem. I was cruising along the highway this morning and it was boosting at max 13-14psi. So I got my vgate vscan unit out (similar to actron) and just hit the erase codes button while driving. I got back on the throttle and my boost went up to 20psi. Car is not throwing any codes now. In the past it would give me a pending PO101 code and only boost to about 4psi. Like it goes into a shutdown mode. I've only had the car for. A few weeks....still learning about these things. Any help would be awesome.
I made the boost leak tester. I just got done testing, the system seems to be holding pressure just fine and the only place I can hear a tiny tiny bit of air coming from is the hose off of the engine for the PCV valve where I disconnected it from the intake.
firehawk618
11-15-2015 08:07 PM
CobaltSSTC
11-11-2015 09:30 PM
