BOV - The myths and the truths
Old 04-22-2010, 02:31 PM
  #51
leoaa777's Avatar
Originally Posted by JPizzle
I have had my HKS BOV VTA with the Dejon CP's for almost 1 year (It will be 1 year in July). That was stock, and it ran fine. I now also have the GMS1, and still no problems! Ernie (Negrita SS) installed the CP's & BOV for me. He did a FANTASTIC job! I am NOT using a block-off plate. And I am not using a MAF Relocation setup either. I have no trouble with it at all. I make the same power similar LNF's make and I don't surge or flutter at all. Here is a picture on how he wired it up:
Aaaaand that picture shows clearly why charge pipes are unnecessary in these cars.
Loss of air velocity much?
Old 04-22-2010, 02:36 PM
  #52
09turbo's Avatar
sub'd
Old 06-16-2010, 02:18 PM
  #53
Southtown57's Avatar
What? Do you even own this car to see how awful the factory charge pipe is?
Old 06-16-2010, 02:26 PM
  #54
Shez's Avatar
Seriously... Stock piping is so restrictive and just piece of **** plastic.
Old 06-16-2010, 02:49 PM
  #55
beast10007's Avatar
I have a HKS ssqv the I had on my old eclipse....I am about to buy zzp upper. now what all do I need to do?
just the vac line?
Just block off plats? or both?
I Just want to know the best
thanks
Old 06-16-2010, 02:51 PM
  #56
just the vac line?
thanks
ZZP upper charge pipe only works with the tial bov.
Old 06-16-2010, 04:33 PM
  #57
beast10007's Avatar
I was going to weld an HKS flang on it
Old 06-16-2010, 11:45 PM
  #58
JPizzle's Avatar
The HKS should come with a "T" split. And you can see in that diagram (It's my car) on how it's routed & tapped off of the vac line.
I don't have a Block-Off Plate either...
Old 06-16-2010, 11:47 PM
  #59
Just wanted to make sure you knew the flange that came with it was for Tial so you didn't receive it and have a WTF moment.
Old 06-17-2010, 11:12 AM
  #60
blk06ss/sc's Avatar
im running tial bov with cia performance piping, holding 25lbs no issues at all, with maf relocate, tuned by vince i love it tial sounds sick also
Old 06-17-2010, 11:32 AM
  #61
aweSOMeBalt's Avatar
some good info here
Old 06-24-2010, 09:45 PM
  #62
RossGo's Avatar
Anyone have any success or trouble with the zzp/tial?
Old 06-24-2010, 10:17 PM
  #63
Gestapo007's Avatar
my interceptor shows my car going rich between shifts. The car enters the mode terminator was talking about sometimes, but from what i witnessed only under a higher RPM. theres plenty of times i let off and my A/F reads rich. I believe i have a video to prove it.
But i still run my HKS BOV, and i DONT run a block off plate b/c i feel if both BPV and BOV are performning propely, a certain amount of air still makes its way back into the recirc line, and i know this to be true as I have the hahn intake and you can clearly tell under low boost it sounds alot like a normal hahn BPV sound. Well I have no surging and flutter with this setup, and I hear mostly the HKS on let off. Vacuum lines are not "T"'d into my Intake manifold line, there T'd into the Stock BPV line.
Old 07-08-2010, 07:06 PM
  #64
beast10007's Avatar
But i still run my HKS BOV, and i DONT run a block off plate b/c i feel if both BPV and BOV are performning propely, a certain amount of air still makes its way back into the recirc line, and i know this to be true as I have the hahn intake and you can clearly tell under low boost it sounds alot like a normal hahn BPV sound. Well I have no surging and flutter with this setup, and I hear mostly the HKS on let off. Vacuum lines are not "T"'d into my Intake manifold line, there T'd into the Stock BPV line.[/QUOTE]
This is what I just did I love it! car sounds sweet PHHHSSSSSSSSSSS.
also with the charge pipe I can hear the turbo spool a little better.
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
hacadacalopolis
10-28-2015 06:09 PM
anotherslowlnf
09-29-2015 03:52 PM
breds2k
19
09-21-2015 10:24 AM
Quick Reply: BOV - The myths and the truths
