Bullseye Power Batmowheel for Ko4
#127
so far, BEP has yet to have a batmowheel fail to produce better results. its not just the power increase, but you can actually feel it on the butt dyno with the change in over all power band. batmowheels not only spool faster than the wheels they replace. but they also carry the power out past where the factory wheel would run out of breath
#129
yes if you just order the wheel it will come with instructions. but chances of balancing a wheel being installed on a turbo with miles already on it, aren't very good. if the turbine shaft is slightly off balance, say 1-2grams, installing the compressor wheel will throw it off by say 3-4grams. i would reccomend sending in your turbo to them to have the wheel installed. the price for sending in your turbo is the same price as it is to order the wheel. installation and balancing is free, you'll just pay more for shipping
#131
if there is turbine wheel damage to your turbo, they will not be able to rebuild it. if it just has some shaft play or something minor they will be able to rebuilt it. use the repair request from on their contact us link.
Bullseye Power Turbos
#145
