Bullseye Power Batmowheel for Ko4
#154
#155
No its got a cluthmasters stage 4 in it, yeah I thought the numbers would be a tad bit higher but it was pretty warm out (86 degrees) and the humidity was 42%. Another guy with similar mods minus the meth kit dynoed 320whp and 420wtq on the same dyno but his run had a lower humidity and the temperature 77 degrees and he was on 24 PSI vs mine which is only 22 PSI. I could have bumped the timing up as well. On this run it was 18 degrees peak and on the street we had it up 22 degrees with no knock.
#165
this!!! i just dont want to see results post batmo where boost is 25psi and 22* timing with gains of 40-50whp.....that would be very misleading. he seems to have a conserative tune with a little lower boost than a lot of others run and very conservative timing for running meth. there will be potential for huge gains on his setup when the batmo gets installed if it is tuned more aggressively.
#173
