Car wont Stay running
2009 SS
got in my car to head home one day and it started and ran like junk, turned the car off and started it again and it ran for a few seconds and shut off.
Had the car towed to a local shop, they told me that the PCM was bad
ordered a tuned pcm from ZZP with 3bar map sensors (hey why not upgrade?)
shop was holding my car longer than they should so i went down there and had it towed to my house.
Installed new pcm and sensors.
car started just fine, CEL came on.
looked under the hood and noticed the shop unplugged my MAF
plugged it back in and started the car
car died after running for a few seconds like before i installed the pcm.
Replaced the MAF, still same results...
anyone have a clue what would be causing this?
Final update!
I bought a new MAF the other day and tried to plug it into the harness. I made a mistake when i did this, I didnt realize that the computer needs airflow from inside the intake in order to function correctly. I went back out, and installed it in the intake, plugged the sensor in, and BOOM, it worked. cleared the codes and it runs great now.
now what do i do about the dealership that told me the pcm was bad when they knew it was just the MAF, i bought a new PCM because of their error. i know that they knew it was just the MAF because when i got my car from them the MAF was unplugged. they forgot to plug it in prior to me getting it from them. what would you do if you spend $550 on a new pcm because a dealer lied to you, instead of $50 on a new MAF?
CudaJoe (02-28-2019)
Call the dealership and tell them you are going to express your dissatisfaction on social media. Don't be emotional and don't accuse them of anything. Explain your loss to them and see what they say. They probably don't care, because you aren't going to come back for service or to buy a car. It's worth it to give them a chance to make amends, though.
Unfortunately I do not see them reimbursing you for the PCM cost, but it would be wrong of them to not at least refund the money you paid for the misdiagnosis.
I too have two PCMs. I have my OEM one and a BYT tuned one. Although I only spent $200 on mine with tune. It was a deal tho... not the usual case.
C_A_D88
07-13-2012 04:19 PM
