Check Engine
Check Engine
mass air flow...
changed the Air Filter & mass air flow sensor
removed Code...all is good until i restart the engine, code comes back
i remove code while idling, no code while driving
turn off engine, later restart, code is back
i did notice before changing the sensor, engine was idling irratik, since new sensor
engine not running smoothly
any idea's
2009 Turbo with 50000K
any idea's
up-date...
clear code, turn off key wait 2 minutes turn key on without starting engine
code is back, clear code again repeat, code comes back
checked wiring all seems ok, no broken wire
You're going to have to follow the wires back to the ecu. The code cause from https://service.gm.com/gmspo/mode6/p...F%20Engine.pdf says the monitored voltage of >10.5V
