Crazy Steve Install Pics
Old 10-02-2009 | 02:10 PM
mongorat427's Avatar
Here are some pictures of my Crazy Steve intercooler install. Yes that is my blood all over the bumper support !!!
https://www.cobaltss.net/gallery/fil.../a100_1215.jpg
https://www.cobaltss.net/gallery/fil.../a100_1216.jpg
https://www.cobaltss.net/gallery/fil.../a100_1220.jpg
https://www.cobaltss.net/gallery/fil.../a100_1218.jpg
Old 10-02-2009 | 02:26 PM
09cobaltsc's Avatar
it aint yours without ur blood on it
Old 10-02-2009 | 02:27 PM
burnrubr88's Avatar
Man that IC is the freakin sex.
Old 10-02-2009 | 02:29 PM
Gestapo007's Avatar
i cant wait to get that intercooler. its only like 250 aint it.
Old 10-02-2009 | 02:31 PM
ecotecturbo's Avatar
From what i heard people where having trouble with fitment issues. Ive heard few people say theres didnt fit the aftermarket charge pipes.
Old 10-02-2009 | 02:33 PM
LE5_AJ's Avatar
mine fit in my car just fine with stock it was a tight on the ic with the injen cp it fits nice the only problem i have is i'm getting a TON of pressure drop
Old 10-02-2009 | 02:42 PM
cardelino18's Avatar
got any pics with the bumper on? also feel any difference performance wise? also how long ago did you order it?
Old 10-02-2009 | 03:18 PM
Terminator2's Avatar
Mine fit like complete crap. It hit the crash bar and condenser and it was not even lose to the correct alignment with the CPs.
Old 10-02-2009 | 03:24 PM
CudaJoe's Avatar
hmm... soo Crazy steve intercooler = not a good buy? what are a good set of charge pipes to go with it?
Old 10-02-2009 | 03:26 PM
Injen's Hot pipe with a set of T-bolt clamps is the best IMO. Cold pipe is not worth the trouble IMO.
Old 10-02-2009 | 03:42 PM
Smile Fitment
Originally Posted by mongorat427
The intercooler is made to fit on the extra 2 bottom bumper brace holes. The 2 tabes were off by about 1/4 inch so I elongated them which is easy on aluminum. The tabs have to go in front of the bumper brace for proper bumper fit. excess material needs to be romoved from the brace to clear the intercooler starting about 3/4 inch from the mounting holes remove about 3 inchs of metal X 1 inch deep with a grinder. This allows the intercooler to be mounted so the bumper brace ends up in the stock location.Test fit it a few times and then test fit it with the piping hooked up. Clean up all edges with a die grinder or file. You can also bend the tabs a little for fine tuning the fit.
After testing it I noticed the car was a little quieter below 2500 rpm and much louder above and difinately felt good with the tune turned on.
For $250 and about 5 hours of your time its a killer deal. (Car runs like a raped ape 155 MPH in fifth with 1000rpm to go}
Mine fit the Dejon charge pipe perfect and the stock GM out pipe also.
My car is a 2009 SS TC 8 weeks old. AEM Intake , Dejon Charge pipes , Hahn Catted Down Pipe , Jennetty 3 inch exhaust , Engals Stiffy Dampiner , OTT stage 2 mounts , Trifecta Infina Boost Dual Tune ( still need final tune) Coming up Spec stage 3 over the winter
Old 10-02-2009 | 03:44 PM
Supercharged Guy's Avatar
Looking good man
Old 10-02-2009 | 03:53 PM
Dejon Charge Pipes
I have Dejon charge pipes with the premium clamps . They fit perfect.
I put it on a week ago and ordered it about 2 weeks before that. Took about 4 working days to get to me.
Im in arizona on vacation right now but will take some more closeups when I get home in 12 days.
Old 10-02-2009 | 03:58 PM
Scythe_Snake's Avatar
looks good. But I don't know if I like the positioning of the end tanks. The bumper is covering up part of the surface area, and the end tanks are on the bottom of the IC, not around the middle.
But it looks like you all had fun. Keep it up!
Old 10-02-2009 | 04:42 PM
Smile
Ill keep everyone posted on how it runs when I get back.
What else is done to your car? It will work better on a car with a lot of mods and a tune.
When your running 23 or 24 pounds of boost at 7000 RPM it does not matter as long as the air around the intercooler is cool. It will be cool in 2nd gear and above and blasting through the intercooler with that boost. Im still trying to figure out 1st gear though , Ha Ha Duh
Old 10-02-2009 | 04:45 PM
1badBlueberrySC's Avatar
That intercooler is eh at best...
The Dejon pipes suck! PERIOD I wish everyday I didn't buy mine. But I finally got them from popping off!
Old 10-02-2009 | 05:17 PM
Eh, I dunno. i'd still rather have my air cooled even a little bit more. When it runs across the bottom it doesn't use the surface area of the IC as much ya know. I would rather my end tanks be through the center. I'm not knocking it though bro, a FMIC is an FMIC
Whats wrong with the DEJON pipes? What sorts of issues are you having with them?
Old 10-02-2009 | 05:32 PM
Which connectors did you get with yours ? I have no problems at all with mine with the premium connectors.
Old 10-02-2009 | 06:20 PM
SSlobalt's Avatar
I bet BB has he premium connectors. It doesn't seem like something he'd skimp on.
Old 10-02-2009 | 06:25 PM
Sweetsandman's Avatar
Well clearly a problem with them popping off
Old 10-02-2009 | 06:44 PM
Shez's Avatar
I lol'd.
I never had a problem with mine.
Old 10-02-2009 | 06:51 PM
Originally Posted by Shez
I lol'd.
I used the T Bolt Clamps with the nylon locking nuts and they never popped off. I know if you use the regular radiator style clamps they can back of and the pipe will work its way out.
Old 10-02-2009 | 11:10 PM
Gestapo007's Avatar
my dejon holds up pretty well. hope to either get this or a downpipe in the next coming months
Old 10-03-2009 | 12:12 AM
I can state without a doubt that you guys aren't pushing as much airflow as I am... hence the popping off.
It took silicone couplers, tbolt clamps and hairspray to get them to ******* stay on!
Old 10-03-2009 | 01:29 AM
Gestapo007's Avatar
i call shenanigans
