Dataloging question
Dataloging question
Hey everyone,
When I datalog my car, it won't show me afr, knock retard, boost, VE airflow, excam angle, intcam angle, load or iat2 data.
How come? Is there something I need to do so it will show this stuff?
Yeah I'm talking about hp tuners. I snagged up the config that byt had in the thread on how to tune an lnf....I see why it didn't show anything. That's because with all those things listed above, there's no pid or sensor connected with the label.
Also when I checked the dtcs, it shows incomplete for catalyst, 02 sensor and evap system....isthat normal?
Pretty much. HPT isn't plug & play. Hope your in for a learning curve. Best to join that forum. Even if you download someone elses config file, you still have to build the custom PID's up. There are ways around it though.
You going to tune yourself or get an email tune done?
Here's a link to Shabby's config & the PID's you need to add. Then you can customize the charts as you wish but the table has to include the PID's first.
HP Tuners Bulletin Board - View Single Post - Scanner Configuration & Histogram Repository
