Direct bolt-on turbo (ko4 replacement)
Old 08-28-2012 | 07:56 AM
  #401
Chevycobaltss3's Avatar
55/55 so in is 55mm while exhaust is 55mm. In isn't to bad but it's 2mm larger then a 20g/bnr and exhaust is smaller so top end will fall . And in order to support 510hp then that would be 650-750cfm turbo. I could see it but it's not gonna hold its own up top. But only way the said power will be seen is going way over efficiency and high octane. But should still be a good turbo
Old 08-28-2012 | 10:49 AM
  #402
alerosaint's Avatar
Thats what im looking for in a turbo...still in its efficiency range at the top end. Pulling all the way to 7k and wants to go further.
Old 08-28-2012 | 12:36 PM
  #403
40rty's Avatar
So as for the revised BNR, looks like for $300 you will get a new lighter compressor wheel that will spool quicker and hold boost better up top.
Hmmmmmm
Old 08-28-2012 | 12:37 PM
  #404
Fastgti69's Avatar
Instead of making the compressor housing slightly bigger. Why not make the exhaust turbine AR slightly larger for better top end power. I understand more lag, but its pretty much a tiny turbo still lol..
Old 08-28-2012 | 07:53 PM
  #405
Sully20's Avatar
Hmmmmmm
Diizzamm, You got my interest sparked now! So now this BNR will Spool quicker? Cause thats the reason why I really wasent considering it before, Whats the spool time? Any where close to stock?
Old 08-28-2012 | 11:31 PM
  #406
Frogstofall's Avatar
In all honesty a quicker spool is only gonna make the trans situation even worse.
Old 08-28-2012 | 11:52 PM
  #407
40rty's Avatar
No trans situation here
Old 08-29-2012 | 01:13 AM
  #408
I meant for us Cobalt people.
Old 08-29-2012 | 06:11 AM
  #409
oldskool's Avatar
I'm highly interested in details of the WR-3. I started a thread on solstice forum; it should be a matter of time before Werks chimes in, they are very good with communication on our forum.
Old 08-29-2012 | 10:47 AM
  #410
40rty's Avatar
^^^ Hey, make sure to go on Kappaperformance and post in the Dyno thread there your dyno results. Thanks.
Old 08-29-2012 | 12:35 PM
  #411
Sully20's Avatar
Meh, Maybe you've got a point, but I still am looking for something that spools close to stock as possible, Really dont want to wait till 4,000rpms for my sh** to spool lol.
Old 08-29-2012 | 04:04 PM
  #412
It actually does help a bit with traction to have that slight delay but I get what you're saying.
Old 08-29-2012 | 07:59 PM
  #413
40rty's Avatar
Opan gangnam style!!!!!!!!!!!!!
Old 08-30-2012 | 12:12 AM
  #414
AARON-SS-TC's Avatar
how much is the new revised bnr without core?
Old 08-30-2012 | 11:48 AM
  #415
elecblue06's Avatar
probably full price of 1200
Old 08-30-2012 | 11:53 AM
  #416
JBThrasher22's Avatar
Without core he said so 1200 + 300 core fee ( if Brian will let you have one without a atm since he doesn't have many cores in stock I don't think ).
So around $1500.
Old 08-30-2012 | 12:57 PM
  #417
So around $1500.
oh okay, anyone know when the revised ones will be out?
Plus, does it come with all the hardware to bolt-on? if not, what else is needed?
Too much negativity around the Hahn setup, even though it looks to make good numbers, and its mad cheap, i may just do a damn BNR...lol
Old 08-30-2012 | 01:25 PM
  #418
Dart_SI's Avatar
the BNR comes with everything except a BOV, which you will need. its easy to install, take off the stock turbo, put on the BNR. done!
although bending the stock coolant/ oil lines was a PITA for me. I talked to Brian and he said he could include some hoses and fittings to make it way easier to install. id ask him about that if you order one.
and i imagine every BNR from here on out will be the "revised" version.
Old 08-30-2012 | 01:29 PM
  #419
Projekt's Avatar
Dart how much did you make on the dyno with your BNR?
Old 08-30-2012 | 01:32 PM
  #420
kdub1492's Avatar
So all we would need is Upper CP with BOV and we are good to go? This may be the route that I go.
Old 08-30-2012 | 01:55 PM
  #421
cubaniche's Avatar
Supporting mods, like the ones you already have, are necesary, I would say. You dont NEED a new upper CP for the BOV. I had my Injen upper CP cut into and modified for the BOV I wanted to run. If you want a clean start then, yeah, you can spend the extra cash and buy yourself a BOV ready upper CP. Its up to you.
Old 08-30-2012 | 02:11 PM
  #422
Dart_SI's Avatar
i never dynoed with the tune finished.
i was running basically a base tune for a couple weeks since me and area ran into some issues tuning (for some reason my stock boost solenoid just wouldn't work properly).
There was a dyno day and it was $30 for me to hit the rollers so i figured why not.
area47 told me not to expect high #'s at all because he needed to finish my tune.
on 25 psi i was hitting about 350whp. cranked it up to about 26-27 and hit 364whp. I run 29 psi on Kill and id imagine if i was on that base tune still itd be around 375whp or so.
Now that the tune is finished, i really need to dyno again because the car feels a bit faster than it did before the tune was finished.
he spent like 2 full days tuning my car. lol. first day took so long because of the boost issue, the second time he was just very thorough. Hes a wonderful tuner.
heres a little pull on the base tune and about 26 psi.
BNR2871 cobalt ss 40-115 - YouTube
and heres after the retune.
little 3rd gear pull - YouTube
Old 08-30-2012 | 02:29 PM
  #423
And not to disagree with Dart but it took me all of 30 seconds to bend the coolant feed line. If you remove it from the hose it's connected to and put it in a vice, it's so easy.
The oil feed on the other hand can be a pain. I found that if you push up and then use the compressor housing as leverage you can bend the oil feed with it and it will fit right on. The other two lines are cake.
The person that bought mine got a sweet deal that's all I know.
Maybe Cubaniche can post the info I sent him about making your own lines. The coolant lines are M14 x 1.5 banjo but the oil feed is some other thread pitch and I can't remember what.
Old 08-30-2012 | 02:33 PM
  #424
sebleroux08/tc's Avatar
Just got a wod of cash back from insurance for over paying, and my rims are back ordered for six more weeks... Hmmm why is that BNR so tempting I have evrything ready for it
Old 08-30-2012 | 02:37 PM
  #425
Projekt's Avatar
Im deciding between the BNR and 20g
