Direct bolt-on turbo (ko4 replacement)
Old 10-30-2012 | 08:46 PM
  #576
Fastgti69's Avatar
Congrats dude! Looks like a very good kit to be honest. Can't wait to see some numbers!
Old 10-30-2012 | 10:35 PM
  #577
Omiotek's Avatar
tyler. glad your happy. i told you it would be well worth it
Old 10-30-2012 | 11:29 PM
  #578
Gunney_07's Avatar
totally was and it's not even on yet... would you tell Dave thanks for the upgrade for me?
Old 10-31-2012 | 03:42 AM
  #579
Omiotek's Avatar
sure thing. i can do that for you. cant wait to see results.......
Old 10-31-2012 | 09:57 AM
  #580
Dart_SI's Avatar
Originally Posted by Gunney_07
Is that a turbo to manifold gasket or spacer?
Old 10-31-2012 | 10:19 AM
  #581
Omiotek's Avatar
Should be bother. Gaskets and a spacer
Old 10-31-2012 | 10:24 AM
  #582
Dart_SI's Avatar
I was told by Bryan @ BNRsupercars that the little center section of the spacers for the BNR turbos would crack or even break over time. If that happens, its going to take the turbo with it, so he told me to cut out the center section on the spacer.
Im not saying the spacer IS going to break or crack, but it makes sense. I cut out the center section of mine before i installed my turbo. BNR also sells the spacers without the center section anymore for that reason.
Old 10-31-2012 | 10:30 AM
  #583
Omiotek's Avatar
So I assume you cut out the section in the manifold too? I mean they crack and I've seen then bad enough where there's small chunks missing out of them too where the cracks met. Esentially you have the same problem there too it will take out the turbo. The spacers should not crack. Did bar see cracking in theirs?
Old 10-31-2012 | 11:03 AM
  #584
Stamina's Avatar
Truth. My friend's BNR setup totally melted away the divider on the spacer and possibly messed up the turbo. The divider on the manifold was fine, with the usual crack.
Old 10-31-2012 | 12:27 PM
  #585
Dart_SI's Avatar
Just give bryan at BNR supercars a call. He's a smart guy. Makes all those hybrid turbos himself.
Old 10-31-2012 | 12:50 PM
  #586
AARON-SS-TC's Avatar
Well, sadly it will be spring time before that happens as my car is up for winter storage... but come good weather again I have a spare head with zzp cams and spring to install along with the WR-2b
whaaaaat. all that waiting and you are not even putting it on till next year? omgawd...lol
Old 10-31-2012 | 01:08 PM
  #587
Stamina's Avatar
Old 10-31-2012 | 01:46 PM
  #588
Boosted4's Avatar
Old 10-31-2012 | 01:58 PM
  #589
Gunney_07's Avatar
trippy
Old 11-04-2012 | 03:09 PM
  #590
Team SS's Avatar
TTR Powered
Correct, Bryan now just sells the Center Less Spacers.
First day i had mine, i cut it out. even tho the stock Exhaust Manifold center Section was cracked (Which is Normal on all LNFs)
Old 11-04-2012 | 05:23 PM
  #591
i dont see any zfr on this list or wr-2...frog is the only bnr i see as well.
2.0 T/C - All Out POWER POTENTIAL!!
Slap a big snail on it, build the motor, get nitrous injected, whatever it takes to MAKE POWER on a 2.0 T/C LNF
1. Matt M (ZZP) 607whp, 547wtq Verified Mustang TK/CP/IC/CAM/CB/E85 Graph
2. FasterIsBetter, 508whp, 473wtq, Verified Mustang Dyno, E/T/ZZPtk/PI/PH/FI/E85/OB/FS/CP/IC/C/GM1S/CD/ZZPGirdledBlock, Graph
3. cmiller8006, 501whp, 447wtq Verified Mustang Dyno, E, T, ZZPtk, CD, TB, C, RG, IC, CP, FI Graph
4. gone_in_10_sec, 486whp, 517wtq ZZPtck/H/DP/CD/SRI/CP/IC/T/C02/N2O-75/RG Graph
5. 1badBlueberrySC, 455whp, 410wtq Verified Dynojet, PTE2871r(22psi)/H/DP/CD/CP/WI/T/E Graph
6. CMVsst2010, 411whp, 374wtq, Verified Mustang Dyno, S256et/DP/IC/CP/I/T, Graph
7. Frogstofall, 408whp, 383 wtq, Verified Dynojet, I/DP/T/GM1S/E47/IC/CP/BNR2871(24.5psi), Graph
8. FrossB 407whp, 391wtq Verified Dynojet, PT5557/I/CP/H/E/T/IC/ 91oct.
9. Donkeyballs 398whp, 397wtq Verified DynoJet IC/CAI/CP/DP/CD/T/TK EFR6758 23psi Graph
10. Chevycobaltss3, 398whp, 394wtq, Verified Dynojet, TK(20g)/I/CP/DP/E/IC/T, Graph
11. Mezzano 381whp/381wtq Verified SAE corrected GT3076r/CP/IC/DP/CD/E/T Graph
12. jmarks, 373whp, 401wtq, Verified Dyno, GT3076/I/E/T/TK/CD/IC/CP, Graph
13. gone_in_10_sec, 370whp, 380wtq ZZPtck/H/DP/CD/IC/CP/I/T/C02 GRAPH
14. mkriebs, 368whp, 387wtq Verified Mustang Dyno IC/CD/DP/Werks 5557 TK/T Graph
15. badbaltguy, 356whp, 363wtq Verified DynoJet IC/CAI/CP/DP/CD/E/T/s20g(25psi) HP Graph TQ Graph
Old 11-04-2012 | 05:40 PM
  #592
Team SS's Avatar
TTR Powered
I posted my 415whp on bnr2871 in there. just waiting for it to be added
Old 11-04-2012 | 05:59 PM
  #593
cool...details?
Old 11-04-2012 | 06:05 PM
  #594
Team SS's Avatar
TTR Powered
cool...details?
here you go man.
Dyno Jet: Track Masters Inc Huntsville AL.
Turbo Tech Racing LNF Manifold.
Revised BNR 2871 Turbo.
K&N Short Ram Intake.
Injen Charge Piping.
TR12 Intercooler.
MAF Relocation Pipe
GMS1 Sensors
Comp Cams Stg 1 W/LFPL
#82 Springs W/ Retainers
Neutral Balance Shafts
Wiseco 86mm Pistons
4340 Connecting Rods
Tial Q 50mm Bov
Full 3" Exhaust With 3" Hahn Muffler (No Cats)
4.05 Transmission W/O LSD
Hptuned by CCSS3
93 Octane Pump Gas Only. (No Meth, No E85, No Race Fuel)
415Whp / 381Wtrq
Old 11-04-2012 | 07:04 PM
  #595
nice numbers on 93 gas for sure, but you are built with cams/springs/pistons/rods and fully bolted, so i guess its to be expected....thanks for that man
Old 11-04-2012 | 07:08 PM
  #596
Chevycobaltss3's Avatar
Cams don't give much if anything. Same with springs and pistons. Being built means more reliable horsepower. His higher rev helps of course
Old 11-04-2012 | 07:11 PM
  #597
Team SS's Avatar
TTR Powered
No problem at all man. the being build doesnt really add much power, it just helps me from going BOOM lol..... again hahahaha
Old 11-04-2012 | 07:25 PM
  #598
40rty's Avatar
Damn it I want that manifold. Why you guys release this while I'm doing my build?
Old 11-04-2012 | 07:29 PM
  #599
Team SS's Avatar
TTR Powered
Because testing is done??
Soon man, Soon you will be a PROUD Owner of a TTR Manifold
Old 11-04-2012 | 07:46 PM
  #600
im tired of all you guys with 400whp, now I want 500whp....lol
No, but seriously, is the ZFR capable of 500whp on 93 gas? and if so, what kind of tune is needed?
