Direct bolt-on turbo (ko4 replacement)
Old 11-05-2012 | 12:33 PM
  #626
40rty's Avatar
Its you lol
Old 11-05-2012 | 12:38 PM
  #627
AARON-SS-TC's Avatar
haha, i know brother. i do look into stuff too much sometimes
Old 11-05-2012 | 12:41 PM
  #628
alerosaint's Avatar
Cant wait to see what turbo you choose aaron....you been struggling with your choice harder than two pitbulls fighting over steak. its actually exhausting lol
  #629
40rty's Avatar
That's not a bad thing at all. I do the same thing.
Old 11-05-2012 | 12:51 PM
  #630
lol, thats a great analagy.
In all honesty, i'm still looking at the s20g set-up to be different and really try to get some results outta it(425whp/400wtq)
Old 11-05-2012 | 01:47 PM
  #631
Team SS's Avatar
TTR Powered
James did a custom setup on his s20g.
But i'm sure whatever setup you go with, you should be happy with it
Old 11-05-2012 | 01:57 PM
  #632
40rty's Avatar
I'll tell you what, with that goal in mind, you will have no problem reaching it with the S20G setup. Just on E47 with supporting bolt-on will yield you that. If I were you though buy a rebuild kit for it($20) just to have handy. I know a guy with a Sky that has the S20G setup and his first dyno made 412whp 441wtrq. Now he's making much more than that with headwork, cams and 5th injector.
Old 11-05-2012 | 02:04 PM
  #633
thanks 4 the info 40rty. is the turbo unreliable?
Old 11-05-2012 | 02:16 PM
  #634
40rty's Avatar
The turbo is not unreliable, they are damn good turberchargers for making power. They just have seals go out on them(Leak oil etc). Ask people in the DSM world about it, they'll tell you.
Old 11-05-2012 | 02:44 PM
  #635
well, thats unreliable if you ask me...lol...thanks again
Old 11-05-2012 | 03:07 PM
  #636
cmiller8006's Avatar
on your graph, the s20g looks okay on 26psi, and the guys on the bnr with 25psi look alright, but they both seem to peak late and drop off before 7k rpms...maybe its me being too critical, dunno.
Generally you can not get both great powerband and top end power on the same setup on such a small motor. You either need to do a bigger turbo with say a small ar on the turbine side to get good spool and then hang on up top. Or be satisfied with a quicker spooling turbo but you might have a power band of 3-6500 rpms or you have a power band of 4500-8000 rpms. The hybrid that ccss3 has is a good piece. About the only one that will have both that you want. Some say there not that reliable. They are just older technology thats all, but again like james', its a good setup.
Old 11-05-2012 | 03:15 PM
  #637
its good to hear that the big dogs on here like the s20g, but why dont any of you have it other than james? Its super cheap, and makes good power/torque on 26psi+, 93 gas, so what is the deal?...haha
Old 11-05-2012 | 03:23 PM
  #638
Here is a graph of my 5857
Old 11-05-2012 | 03:26 PM
  #639
40rty's Avatar
Aaron, then get it man! Dude I can't imagine the day you finally get a turbo(whatever it is), this forum will explode of so many threads being started by you.
Old 11-05-2012 | 03:30 PM
  #640
lol, common' man..i have made some great and informative threads on here...i am 32 years old, so i have a differnet way of buying things, i research...lol
CMILLER, that graph is flippin awesome man. it dropped like crazy from the 28psi power to 32psi though.
  #641
Like I said old technology. You can get a bigger lighter weight turbo now a days and make more power with the same spool times and what not. And like 40rty said, there known for having leaking seals and issues like that.
Old 11-05-2012 | 03:33 PM
  #642
What do you mean dropped like crazy? The boost curve? That was actually do to a sticking waste gate. The precision wastegate ended up not being as good as a tial. Got home and switched it over to a new pte46 and the issue went away.
  #643
40rty's Avatar
cmiller, that graph is flippin awesome man. It dropped like crazy from the 28psi power to 32psi though.
lmao
Old 11-05-2012 | 03:35 PM
  #644
Or are you talking about the average hp to the max hp. The average boost was 28psi and the max was on the spike at 31.2 psi, and the average hp which is kindof irrelevent because it is using the spool up time as well.
Old 11-05-2012 | 03:36 PM
  #645
Chevycobaltss3's Avatar
Well first thing, both turbos don't loose power up top unless its a inefficient boost setting. That goes for all turbos. The 20g on "24 with a spike of 26" didn't loose one bit of power. Just tq.
I also never said you can make 500whp on the 20g. I said you can make good power on the 20g.
And I'm on a custom turbo setup I've made... It's stil a td06/t3 cartridge but the 20g is a 52mm and my new in wheel is a 63mm along with a 3in compressor cover with surge protection. This turbo I'm at now makes 950/975cfm per mitsu and Garrett tables I've seen.
Old 11-05-2012 | 03:37 PM
  #646
haha, no i meant a huge power difference in 28psi to 32psi...that graph is the best i have seen on here though
Old 11-05-2012 | 03:39 PM
  #647
And btw rebuilding the mitsu turbos are cake. Cheap as well
Old 11-05-2012 | 03:43 PM
  #648
i wish there was a way to have the precision turbo as a bolt-on
Old 11-05-2012 | 03:45 PM
  #649
Omiotek's Avatar
its being worked on....wr2 type b is a percision.....wr3 is percision.....
Old 11-05-2012 | 03:47 PM
  #650
They make an adapter ! Dejon.. It's what I'm using, it bolts up to te stock mani to a t3 flange
And team Ss and I are working with bnr racing on a new direct bolt on turbo
Last edited by Chevycobaltss3; 11-05-2012 at 03:47 PM. Reason: Automerged Doublepost
