Direct bolt-on turbo (ko4 replacement)
Old 11-05-2012 | 03:48 PM
  #651
kdub1492's Avatar
Originally Posted by omiotek
its being worked on....wr2 type b is a percision.....wr3 is percision.....
^ this
Old 11-05-2012 | 03:49 PM
  #652
Omiotek's Avatar
Originally Posted by kdub1492
^ this
also the wr2 standard is percision as well but the type b and wr3 have a large compressor housing.
Old 11-05-2012 | 03:58 PM
  #653
40rty's Avatar
Originally Posted by Chevycobaltss3
Well first thing, both turbos don't loose power up top unless its a inefficient boost setting. That goes for all turbos. The 20g on "24 with a spike of 26" didn't loose one bit of power. Just tq.
I also never said you can make 500whp on the 20g. I said you can make good power on the 20g.
And I'm on a custom turbo setup I've made... It's stil a td06/t3 cartridge but the 20g is a 52mm and my new in wheel is a 63mm along with a 3in compressor cover with surge protection. This turbo I'm at now makes 950/975cfm per mitsu and Garrett tables I've seen.
This was a seperate question James from me and only me. It had nothing to do with what Aaron was asking besides me being curious about a total maximum output of the S20G
I say 480 and some change max
Old 11-05-2012 | 04:01 PM
  #654
Chevycobaltss3's Avatar
I know, I didn't feel like posting twice lol. The 20g flows 650cfm
Old 11-05-2012 | 04:02 PM
  #655
40rty's Avatar
Originally Posted by AARON-SS-TC
i wish there was a way to have the precision turbo as a bolt-on
LOL, bro I facepalm(in a brotherly way) when you ask this and I understand that your just wanting to see what your options are, but this was discussed before when we posted pics and info about the WR2....it has a precision center cartridge. So... your wish has been granted.
Old 11-05-2012 | 04:08 PM
  #656
AARON-SS-TC's Avatar
whaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaat.
LOL. How did I miss that after all this research that the flippin pwerks turbo was precision?
I'm in on this. the price sucks ass, but precision turbos seem to have it all.
Sorry for being a ******* this time...haha
Old 11-05-2012 | 04:12 PM
  #657
kdub1492's Avatar
The price is getting what you pay for. It's a great turbo, with alot of potential. Will get you the power goals that you want. Plus after the core charge the price falls back down to a reasonable one. I say if you do go with the wr2, go with the type b. It has the larger compressor housing
Old 11-05-2012 | 05:09 PM
  #658
sounds good...im all in...thats right, unless something happens, i will be buying the wr2-b by the end of the year hopefully...
i wonder what psi i would need to be at to get the 425-450whp on 93 gas???
Old 11-05-2012 | 05:34 PM
  #659
40rty's Avatar
24-26psi is my guess, Aaron what is your goal? I've seen 419whp-425, now your asking about goals in the 425-450 range. Like I said, I can tell your very excited, as I am for you but you change mind on an hourly basis. Anyways, the Werks turbo is going to be a badass turbo. End of the year huh? So I'm guessing Santa is bringing you this turbo? Maybe I should just go straight to him to figure what turbo you'll eventually get. LOL
Old 11-05-2012 | 05:39 PM
  #660
The wr-2 is a small turbo.. More then 25 is needed (my opinion)
Old 11-05-2012 | 05:48 PM
  #661
Team SS's Avatar
TTR Powered
They make an adapter ! Dejon.. It's what I'm using, it bolts up to te stock mani to a t3 flange
And team Ss and I are working with bnr racing on a new direct bolt on turbo
But will take sometime to finish first james
I've seen the s20g and the s25g at work. and they are pretty dang good turbos IMO.
I mean even the BNR is a great turbo. but you can Farther with the s20g turbo as james did on his.. Which i STILL havent drove it yet hahaha
Old 11-05-2012 | 05:54 PM
  #662
it says its rated for 450whp for our cars, so i just was trying to get an idea of psi is all. thanks james, i was figuring 26-28psi.
James, when do you think you'll have info on what you are trying to make???
Old 11-05-2012 | 06:01 PM
  #663
I'm already done with my custom direct bolt on setup. I doubt ill sell it. The Zzp Efr is rated for 450 (crank horsepower) only way to get more horsepower then its rated is higher boost, aggressive tuning and different fuels with higher octane.
Mfgs of turbos give rated power per turbo output of flow . So it's rated off crank horsepower.
Old 11-05-2012 | 06:08 PM
  #664
40rty's Avatar
There is a 25G? Wow, James please enlighten us with Mitsu Turbo history.
Anyways, I still didn't get a clear answer from you regarding the S20G and what you think Total(Max)WHP is on it. I know that optimally its a 450rated turbo.
Old 11-05-2012 | 06:14 PM
  #665
strazdice's Avatar
where can i get the info on the turbo aaron is talking about getting? zzp said they made 540whp on e85
Old 11-05-2012 | 06:33 PM
  #666
40rty's Avatar
The turbo that Aaron is talking about is by Performance AutoWerks, check it out on there site.
Old 11-05-2012 | 06:36 PM
  #667
20g chp rating is 420-460 depending on what size in wheel, 50mm, 51.5,52mm.
But the Hahn s20g which is a 52mm is rated at 450chp 500chp most with high boost 30psi+
And my turbo isn't just a 25g, I had to find a few parts to make my setup work. You should know about the mitsu family turbos lol
Zzp made that on a lot of boost, I believe there 2.1L, and more.
Old 11-05-2012 | 06:45 PM
  #668
The Home of WERKSracing products!
here ya go. states that it supports up to 450whp
Old 11-05-2012 | 06:49 PM
  #669
after i get my daughters their christmas gifts, i am gonna be my own santa claus....lol
btw 425whp/400wtq on 93 gas and reliable is what i am after...
Old 11-05-2012 | 07:09 PM
  #670
400hp is the point of breaking **** so reliable tilt is out the closet hahah.
Old 11-05-2012 | 07:10 PM
  #671
Team SS's Avatar
TTR Powered
unless your fully built hahaha
Old 11-05-2012 | 07:14 PM
  #672
Fastgti69's Avatar
Efr is rated at 490 chp. It can flow 49lbs/min at 29 psi if i read the compressor map correctly. If i had a choice and i knew what james.did i would have gone 20g got james bigger wheel and housing. Build motor. 500whp+ easy. If u want 400 whp or maybe 450 on super aggresive with e or meth zfr or bnr ot regular 20g is chill. All turbos are great.
Old 11-05-2012 | 07:17 PM
  #673
i know enough to know that 425whp is not gonna blow up my car. i am gonna get the zzp springs/titanium retainers and replace the timing chain tensioner while im in there and i should be fine till 7k redline...you guys like messin with me, but its all good...haha
Old 11-05-2012 | 07:20 PM
  #674
40rty's Avatar
We do but its for your own good in making sure that we can see your car built the right way and ultimately make you happy with your investment.
Old 11-05-2012 | 07:22 PM
  #675
BorgWarner EFR 6758 Turbo - Full-Race.com
