Direct bolt-on turbo (ko4 replacement)
Old 11-05-2012 | 07:24 PM
  #676
Chevycobaltss3's Avatar
Stock pistons are horrid. So if you plan on 400+ and plan on running it like that for a while as a daily it'll break .
Old 11-05-2012 | 07:25 PM
  #677
Rods will be fine, same with crank, sleeve same but I suggest getting a different sleeve setup or something similar, pistons will go
Old 11-05-2012 | 07:26 PM
  #678
40rty's Avatar
Originally Posted by Fastgti69
Efr is rated at 490 chp. It can flow 49lbs/min at 29 psi if i read the compressor map correctly. If i had a choice and i knew what james.did i would have gone 20g got james bigger wheel and housing. Build motor. 500whp+ easy. If u want 400 whp or maybe 450 on super aggresive with e or meth zfr or bnr ot regular 20g is chill. All turbos are great.
This is what I was trying to get out of James. I don't think that the S20G Hahns turbo can yield over 500WHP. On his site they specifically states:
Model: TDO6H-20G-TDO5H-10CM2
Maximum HP Capacity: 500 HP
Optimal HP Range: 300-450 HP
Mounting (turbine inlet)*: T3 style
Exhaust (turbine outlet)*: 3-bolt flange, part number H TZ-7180
Compressor Inlet: accepts 2 ˝” hose
Compressor Outlet: accepts 2” hose
Oil Inlet*: 12 x 1.5mm straight thread
Oil Outlet*: 2-bolt flange, part number H TZ-7190
Optional water-cooling ports: included
This tells me that to the wheels, around 480whp +/-. I just can't see 500+ to the wheels. If I'm wrong then please explain. At 30psi(which I know it can do) it would be out of its efficiency range being that optimal efficiency is 450hp. James?
Old 11-05-2012 | 07:28 PM
  #679
I never once stated a 20g can net 500whp.
I even have you the explanation above.
I'm no longer on the 20g anyhow
Last edited by Chevycobaltss3; 11-05-2012 at 07:28 PM. Reason: Automerged Doublepost
Old 11-05-2012 | 07:40 PM
  #680
Omiotek's Avatar
i never broke with 442whp.... stock top and bottom end, trans and so forth.
Old 11-05-2012 | 07:43 PM
  #681
I didn't break either but that isn't the point. Point is the piston ringlands are **** and will break. No matter a good tune or not. If the car is in boost regularly making 400+ they will go sooner then later
Old 11-05-2012 | 07:55 PM
  #682
40rty's Avatar
I would agree that the stock pistons over 400whp need to be replaced.
Upon further inspection of the pistons looking for signs of this and talking to different shops that collectively have about 80years of experience, all mentioned(while looking at the rings) that under boost it looked like they could of been touching ends.The ends showed cleaned spots of metal. This indicates that they touched at one point while underboost. This would cause them to never be circular in shape again. So this just comes to shows what 26psi on a BNR can do to stock pictons. You can see also that combustion was taking place after the first ring from the crown. Its ok to see slightly a little but not in access like mine.
Cmiller added this to my conversation with him:
Also I noticed when I took my engine apart the first time that the ring gaps are very narrow from the factory, this I believe leads to the ring failures and such because they touch under higher boost where the motors are not built to see from factory.
Just for ♠♠♠♠s I went out and put a stock ring in the bore that was even honed for the wisecos, .015 lol. Way to tight for a high boost motor. The top rings on the wisecos are set at .018 seconds are .020 on my car. I am thinking about total seals for the new motor tho. John what do you think on those?
USMCFieldMP commented:
I have commented on this before. The top rings are usually very, very tight... especially on the LSJ's, so I'd imagine the LNF's are in a similar boat.
John Powell:
I have only ever used stock rings /stock pistons or diamond pistons/total seal on an ecotec, so not sure I am a good source of information. Correct ring gap for a forced induction motor has to be essential, but too large a ring gap especially with oil control rings may result in high oil consumption...
For blown or
nitrous application it is recommended to increase ring gaps
to: .0239 to .0269 for top ring and .0209 to .0239 for second
ring.
from the GM build book
Old 11-05-2012 | 08:18 PM
  #683
strazdice's Avatar
Originally Posted by 40rty
The turbo that Aaron is talking about is by Performance AutoWerks, check it out on there site.
Thanks
20g chp rating is 420-460 depending on what size in wheel, 50mm, 51.5,52mm.
But the Hahn s20g which is a 52mm is rated at 450chp 500chp most with high boost 30psi+
And my turbo isn't just a 25g, I had to find a few parts to make my setup work. You should know about the mitsu family turbos lol
Zzp made that on a lot of boost, I believe there 2.1L, and more.
ya most likely they did it didnt say of course so thats a prolly a good guess, also james how much did it cost to convert the 20g? Did you send it in to a company or do it all yourself?
Old 11-05-2012 | 08:29 PM
  #684
40rty's Avatar
He did it himself, he's a badass like that.
Old 11-05-2012 | 08:33 PM
  #685
Team SS's Avatar
TTR Powered
James, You remember this? hahaha
400whp + stock Piston = Fail
Broke mine in 3 spots
Old 11-05-2012 | 08:35 PM
  #686
strazdice's Avatar
sweeeet!
Old 11-05-2012 | 08:36 PM
  #687
strazdice's Avatar
james much to build me one???? you should market that ****
Old 11-05-2012 | 08:42 PM
  #688
40rty's Avatar
Oh wow, glad someone else has taken pics of their pistons.
Old 11-05-2012 | 08:47 PM
  #689
Team SS's Avatar
TTR Powered
Always lol.
This was my #3 piston...
Old 11-05-2012 | 09:10 PM
  #690
AARON-SS-TC's Avatar
all this negativity towards 400+whp....lol
alright, i have decided to trade the balt for a heffner twin turbo lambo....lolololol
Old 11-05-2012 | 09:22 PM
  #691
Team SS's Avatar
TTR Powered
Wheres the "Like" Button in here?!?!
  #692
40rty's Avatar
Again.... you changed your mind. Lol
Old 11-05-2012 | 09:23 PM
  #693
Team SS's Avatar
TTR Powered
i take it he does that ALOT? lol
Old 11-05-2012 | 10:34 PM
  #694
Fastgti69's Avatar
Really I'm getting scared now. I was saving up for cams and valves. I guess I'm saving to build the motor and that too now. $6k+?
Old 11-05-2012 | 10:37 PM
  #695
kdub1492's Avatar
If you build it yourself you shouldn't spend 6k lol
You don't really need vavles..
New pistons, stock rods are actually fine for 400+
Old 11-05-2012 | 11:18 PM
  #696
I did my setup myself...
Old 11-05-2012 | 11:20 PM
  #697
kdub1492's Avatar
James ur a lint licker
Old 11-06-2012 | 12:06 AM
  #698
Stamina's Avatar
Since everybody is showing off their piston pics, I might as well get in on this action.
Piston failure #1: Cylinder 1, ring bind causing cracked ring/land.
Piston failure #2: A couple years later. Cylinder 4. Royal Purple oil detonation.
Old 11-06-2012 | 12:11 AM
  #699
Only if its in the belly button haha
Old 11-06-2012 | 12:18 AM
  #700
Team SS's Avatar
TTR Powered
