Direct bolt-on turbo (ko4 replacement)
Old 11-20-2012 | 12:51 PM
  #776
Chevycobaltss3's Avatar
Yeah, my last dyno with the 20g I didn't hook usually. Now I don't hook whatsoever.......
Last edited by Chevycobaltss3; 11-22-2012 at 01:11 PM. Reason: Pos smart iPhone. Your stupid as hell
Old 11-22-2012 | 02:32 AM
  #777
AARON-SS-TC's Avatar
lol
Old 11-22-2012 | 01:07 PM
  #778
Team SS's Avatar
TTR Powered
Originally Posted by Chevycobaltss3
Yeah, my last dunk with the 20g I didn't hook usually. Now I don't hook whatsoever.......
Problems lol
Old 11-22-2012 | 02:34 PM
  #779
40rty's Avatar
******* and turbos!
Old 11-22-2012 | 02:37 PM
  #780
Team SS's Avatar
TTR Powered
Originally Posted by 40rty
******* and turbos!
PERFECT for a ThanksGiving FEAST!!! hahaha
Old 12-02-2012 | 09:59 PM
  #781
LNFwagonSS's Avatar
Originally Posted by kdub1492
500+ on E, would be my guess..
We won't be able to get full numbers on E until the spring...that being said, we will have some charts on 93 on different PSI the beginning of December when the car gets on the Dyno
Got any dyno results yet on the WR-3?
Old 12-02-2012 | 10:08 PM
  #782
cant wait to see what the wr-3 does on 93 gas and 25psi. is the spool on it still quick? i am concerned it will be laggy and not be much fun other than on the highway.
Old 12-02-2012 | 10:21 PM
  #783
Team SS's Avatar
TTR Powered
I like highway pulls better lol
Old 12-02-2012 | 10:28 PM
  #784
40rty's Avatar
Rolls are for fat people and those that can't drive :p
Old 12-02-2012 | 11:43 PM
  #785
Team SS's Avatar
TTR Powered
lmao
Old 12-02-2012 | 11:49 PM
  #786
haha
Old 12-07-2012 | 08:06 PM
  #787
kdub1492's Avatar
Hey guys just a quick update. Got the car back and it is running good! WR-3 looks great in the engine! haha We are going to dyno/tune on the 15th...So prolly on the 16th we will have up specs/numbers/graphs etc...
Old 12-07-2012 | 08:43 PM
  #788
Fastgti69's Avatar
Nice!!! lets see some speedo vids~
Old 12-07-2012 | 08:47 PM
  #789
kdub1492's Avatar
Oh trust me, I will get some on the ride home! haha
Old 12-08-2012 | 10:12 AM
  #790
Team SS's Avatar
TTR Powered
In for #s
Old 12-17-2012 | 12:00 AM
  #791
any updates on the wr-2 or wr-3? what about the revised bnr 2871? does bnr have a 3071 option for us?
Old 12-17-2012 | 12:07 AM
  #792
kdub1492's Avatar
I gave some results in my thread...refer to that about the WR-3
https://www.cobaltss.net/forums/2-0l...15/index5.html
Old 12-17-2012 | 01:20 PM
  #793
Team SS's Avatar
TTR Powered
I have a one of a kind BNR setup now
And... I'm not talking about the 2871
Old 12-17-2012 | 01:48 PM
  #794
40rty's Avatar
No you dont
Old 12-17-2012 | 03:59 PM
  #795
Terminator2's Avatar
Originally Posted by Team SS
maybe lol . 415whp 381wtrq on 27psi and only 93octane on the BNR2871 lol
I could have went to 30psi, but the heat was setting in lol.
BNR 2871 is not very stable above 27 psi and you would have had a more massive torque spike but a large fall up top. Hp would have been about the same but reached at a lower RPM and peak torque would been higher of course. Likely 3-4* less midrange spark can be run at 30 psi with the BNR especially on 93 octane. Forty's setup with the 5th injector on E-85 should make around 450-460 whp at 26-27 psi on the dyno dynamics load type dyno he uses. Made 368 whp and 446 wrtq at 24 psi max no huge boost spike with stock turbo on E-85 with the car right on the edge of injection window misfire (6.2-6.5 Ms injection times up at 6500-7200 RPMs even with ZZPs big fuel lobe cams, 2500 psi rail pressure holding throughout (tried higher but would not hold over 2500 psi no matter what I commanded) and a very advanced injection angle
Old 12-17-2012 | 05:51 PM
  #796
Frogstofall's Avatar
Why post half the story? What is it?
Old 12-17-2012 | 05:59 PM
  #797
40rty's Avatar
He's messing with you. Tubular manifold and 5th injector is a unique BNR setup.
Old 12-17-2012 | 07:02 PM
  #798
Actually teams car is similiar to my setup but with a larger turbine wheel but my compressor wheel is larger.
And I'm not seeing 40rtys car hit 450-460 whp on the beaner turbo ... 430-440 on a close reading dyno..
Old 12-17-2012 | 07:46 PM
  #799
So he got a laggy-er version of the BNR is what you're saying??
Old 12-17-2012 | 08:04 PM
  #800
Nope my turbo isn't a 20g its much larger.. Same with teams turbo. Much larger then the 2871.. Teams setup is based off my setup basically just more for his setup because he revs out..
