Direct bolt-on turbo (ko4 replacement)
Old 12-17-2012 | 08:35 PM
  #801
Team SS's Avatar
TTR Powered
Originally Posted by Chevycobaltss3
Same with teams turbo. Much larger then the 2871.. Teams setup is based off my setup basically just more for his setup because he revs out..
Yep
Old 12-17-2012 | 08:55 PM
  #802
Fastgti69's Avatar
Actually teams car is similiar to my setup but with a larger turbine wheel but my compressor wheel is larger.
And I'm not seeing 40rtys car hit 450-460 whp on the beaner turbo ... 430-440 on a close reading dyno..
When 40rty gets his car back and the weather clears up. Me n him gotta meet up and have a go. EFR vs BNR
Old 12-17-2012 | 09:02 PM
  #803
40rty's Avatar
Roger
Old 12-17-2012 | 09:18 PM
  #804
kdub1492's Avatar
I want some action! Lol
Old 12-17-2012 | 09:28 PM
  #805
Team SS's Avatar
TTR Powered
Post vids!
Old 12-17-2012 | 09:32 PM
  #806
40rty's Avatar
Of course, he'll beat me.
Old 12-17-2012 | 10:18 PM
  #807
Chevycobaltss3's Avatar
Can I come?
Old 12-17-2012 | 10:27 PM
  #808
AARON-SS-TC's Avatar
ooh ooh, can somebody race me and beat my a$$ too? Lol
Old 12-17-2012 | 10:36 PM
  #809
kdub1492's Avatar
I can't wait to see the WR-3 on e47 and meth...should be fun!!!
Old 12-17-2012 | 10:37 PM
  #810
brant's Avatar
i want in aalso
Old 12-17-2012 | 11:58 PM
  #811
40rty's Avatar
Can I come?
If you take a Grey hound down here, hell yea.
Old 12-18-2012 | 12:00 AM
  #812
Originally Posted by Terminator2
BNR 2871 is not very stable above 27 psi and you would have had a more massive torque spike but a large fall up top. Hp would have been about the same but reached at a lower RPM and peak torque would been higher of course. Likely 3-4* less midrange spark can be run at 30 psi with the BNR especially on 93 octane. Forty's setup with the 5th injector on E-85 should make around 450-460 whp at 26-27 psi on the dyno dynamics load type dyno he uses. Made 368 whp and 446 wrtq at 24 psi max no huge boost spike with stock turbo on E-85 with the car right on the edge of injection window misfire (6.2-6.5 Ms injection times up at 6500-7200 RPMs even with ZZPs big fuel lobe cams, 2500 psi rail pressure holding throughout (tried higher but would not hold over 2500 psi no matter what I commanded) and a very advanced injection angle
those are pretty good numbers on 27psi David. I think I am goona go the conservative/cheap route, and go with the old school s20g or revised bnr myself. What do you suggest? I was thinking Hahn s20g since not many have it on here, but I am worried i wont break the 400whp/400wtq mark safely on it with what i have(full bolt-ons)
Old 12-18-2012 | 12:10 AM
  #813
kdub1492's Avatar
27 PSI on that is pretty much maxed out tho I do believe. You could go with the s20g, but I believe it will be tough to get to that 400 mark consevativly persay. Don't think it's impossible, just depends on the tuner and what fuel you decide to run
Old 12-18-2012 | 12:52 AM
  #814
Frogstofall's Avatar
Just face it, you're not gonna get any aftermarket turbo. By the time you make up your mind, your car will be a pile of rust in a junk yard somewhere...
I fully bolted, turbo swapped and then returned my car back to stock in the time you were trying to decide what to do!
Old 12-18-2012 | 12:54 AM
  #815
Fastgti69's Avatar
Come down!
Originally Posted by Team SS
Post vids!
Oh yes, there will be vids.
Psh, I don't think that at all. I'm thinking you're gonna rape me.
Can I come?
Please do, and build my motor while you're here.
That is what I'm waiting for...
  #816
yeah you ARE right, i fail....lol
Old 12-18-2012 | 07:42 AM
  #817
SSlobalt's Avatar
Ask lazaro what he thinks of the S20G.
Old 12-18-2012 | 08:00 AM
  #818
Lazaro had a person tune his car who didnt do it right..
Old 12-18-2012 | 08:44 AM
  #819
lazaro's Avatar
And my motor was low on compression i put doen330 on 24 psi on 93
Old 12-18-2012 | 05:06 PM
  #820
S20G 1100
CHARGE-PIPES/BOV 500
= $1600
ZFR 1950 with extended coupler
= 1950
The revised BNR is 1500 - 300 core = $1200+$500 charge pipes/bov = $1700
Pwerks WR-2 $2300-500core = $1800
Maybe its worth the extra 150-350 to do the zfr, but it looks like there is a wait till the summer
Old 12-18-2012 | 05:37 PM
  #821
Terminator2's Avatar
S20G 1100
= $1600
= 1950
Less issues with not having a BOV and MAF relocate on the car is worth it IMHO. Those things if not hooked up and set right are nothing but trouble.
Old 12-18-2012 | 05:47 PM
  #822
Omnigear's Avatar
How about for a road Course /time attack setup? I Dont just Wanna drag the hhr, i Want a dd and Track Car :-)
Old 12-18-2012 | 05:54 PM
  #823
EFR spools up about the same as a 2871 BNR or the WR2 but IMHO it has more top end flow as it is more efficient at higher compressor speeds at least vs the BNR never seen a log of a WR2 car or a compressor map of a WR2. If I still had my Balt I would put a EFR on it in a heart beat.
Old 12-18-2012 | 05:57 PM
  #824
40rty's Avatar
I agree that an EFR is the way to go. They're just tough to find right now.
Old 12-18-2012 | 06:17 PM
  #825
People like the sound of bovs but I'f it sticks open without maf relocate its a bitch
