Direct bolt-on turbo (ko4 replacement)
#801
#802
When 40rty gets his car back and the weather clears up. Me n him gotta meet up and have a go. EFR vs BNR
#812
BNR 2871 is not very stable above 27 psi and you would have had a more massive torque spike but a large fall up top. Hp would have been about the same but reached at a lower RPM and peak torque would been higher of course. Likely 3-4* less midrange spark can be run at 30 psi with the BNR especially on 93 octane. Forty's setup with the 5th injector on E-85 should make around 450-460 whp at 26-27 psi on the dyno dynamics load type dyno he uses. Made 368 whp and 446 wrtq at 24 psi max no huge boost spike with stock turbo on E-85 with the car right on the edge of injection window misfire (6.2-6.5 Ms injection times up at 6500-7200 RPMs even with ZZPs big fuel lobe cams, 2500 psi rail pressure holding throughout (tried higher but would not hold over 2500 psi no matter what I commanded) and a very advanced injection angle
#813
those are pretty good numbers on 27psi David. I think I am goona go the conservative/cheap route, and go with the old school s20g or revised bnr myself. What do you suggest? I was thinking Hahn s20g since not many have it on here, but I am worried i wont break the 400whp/400wtq mark safely on it with what i have(full bolt-ons)
#814
I fully bolted, turbo swapped and then returned my car back to stock in the time you were trying to decide what to do!
#815
Come down!
Oh yes, there will be vids.
Psh, I don't think that at all. I'm thinking you're gonna rape me.
Please do, and build my motor while you're here.
That is what I'm waiting for...
#817
#820
S20G 1100
CHARGE-PIPES/BOV 500
= $1600
ZFR 1950 with extended coupler
= 1950
The revised BNR is 1500 - 300 core = $1200+$500 charge pipes/bov = $1700
Pwerks WR-2 $2300-500core = $1800
Maybe its worth the extra 150-350 to do the zfr, but it looks like there is a wait till the summer
= $1600
= 1950
#821
S20G 1100
= $1600
= 1950
= $1600
= 1950
#822
#823
EFR spools up about the same as a 2871 BNR or the WR2 but IMHO it has more top end flow as it is more efficient at higher compressor speeds at least vs the BNR never seen a log of a WR2 car or a compressor map of a WR2. If I still had my Balt I would put a EFR on it in a heart beat.
