Direct bolt-on turbo (ko4 replacement)
Old 01-02-2013 | 02:29 AM
  #876
Frogstofall's Avatar
Originally Posted by Team SS
The BNR2871 was taken to Bryan at BNR to have all new wheels, bearings, shaft installed.
The asking price is only $800 + shipping.
Also, the BNR is able to hold 30psi, but not on pump gas for very long. 28psi is the max that the BNR2871 Revised can handle for what i've put it thru.
The new One i'm running is a TD06 Custom Built By BNR for me (Buddys with owner)
So basically its the same as the non revised BNR. I ran mine to 28psi on a regular basis. I think he told me the "upgrades" were just for safety and reliability. Doesn't change the efficiency or anything. I never had any reliability issues with mine. $800 would be fair IMO. How many miles on it?
Old 01-02-2013 | 02:32 AM
  #877
AARON-SS-TC's Avatar
isnt the miles irrelevant since everything is new on it?
dunno, just sayin, but would like to know as well.
Old 01-02-2013 | 03:55 AM
  #878
Omiotek's Avatar
only certain things get replaced. not every litle thing is new.
Old 01-02-2013 | 04:50 PM
  #879
Team SS's Avatar
TTR Powered
Miles on it after Revision would be about 300-600miles.
^Thats before i taken it back to Bryan as a request to a Buyer (Which quit his job, So no turbo for him )
Which, Who quits a job a week before christmas??
Old 01-02-2013 | 04:53 PM
  #880
Dart_SI's Avatar
wanna trade for a non revised BNR? lol.
i love mine. I may just keep the car this way for good and buy a weekend toy, but i have the itch to make the cobalt just a little bit faster because i love how surprised people get when an econobox cobalt walks a supercharged v8 or the likes.
im keeping an eye on the wr-3 as a step up. either that or just getting a whole kit.
Old 01-02-2013 | 04:55 PM
  #881
Team SS's Avatar
TTR Powered
I mite can hook you up with the Revision pricing if your nice bahaha
Old 01-02-2013 | 08:05 PM
  #882
Wert842's Avatar
Is the bnr capable of 400whp on 93 and fully bolted? And how is it on the strip? Is it capable of 12s or so? Also, how is the spool time?
Old 01-02-2013 | 08:44 PM
  #883
Team SS's Avatar
TTR Powered
400whp is capable on 93.
i've never taken it on the strip.
spool time is about 2600-3000
Old 01-02-2013 | 09:04 PM
  #884
Wert842's Avatar
Is it capable of 400whp with just bolted or am I going to need more?
Old 01-02-2013 | 09:33 PM
  #885
Team SS's Avatar
TTR Powered
i made 400whp with just bolt ons and 93. with about 26psi
Old 01-02-2013 | 10:04 PM
  #886
Wert842's Avatar
So basically you have it maxed out to make 400?
Old 01-02-2013 | 10:08 PM
  #887
Team SS's Avatar
TTR Powered
I've had it maxed out on 93 pump gas with 27psi in this dyno sheet.
More power can be added with either meth or E85
All depends on your tuner
Old 01-02-2013 | 10:10 PM
  #888
40rty's Avatar
Max at using that fuel. The BNR on ethanol could be max out around 430-450 range on an aggressive tune and 21-27* timing.
Old 01-02-2013 | 10:12 PM
  #889
Chevycobaltss3's Avatar
413whp was made using the TTR manifold.. Not stocker
Old 01-02-2013 | 10:19 PM
  #890
Team SS's Avatar
TTR Powered
415 you mean bro lol
Old 01-02-2013 | 10:57 PM
  #891
kdub1492's Avatar
I would really like to see the log of that 415..
Old 01-02-2013 | 11:02 PM
  #892
I see now. Left out that you were on that ugmo intake manifold. :-p
Old 01-05-2013 | 05:10 PM
  #893
so FROG, you had your BNR on 28psi? what kinda power did you put down?
Old 01-05-2013 | 05:19 PM
  #894
For some unknown reason, I couldn't produce 28psi on the dyno. I could only do about 24psi. I put down 408whp on E47. It was weird bc as soon as I got the car off the dyno, it hit 28psi no problem on the way home. Car was *probably* in the 430whp realm based on the math.
Old 01-05-2013 | 05:24 PM
  #895
I also ran a few local cars that were in that power range and hung or beat them so I figure my guess is accurate.
Old 01-18-2013 | 01:48 AM
  #896
LNFwagonSS's Avatar
Dyno jet?
Old 01-18-2013 | 06:46 AM
  #897
Originally Posted by LNFwagonSS
Dyno jet?
Yup!
Old 01-18-2013 | 10:34 AM
  #898
Omiotek's Avatar
The load is different on the dyno compared to the street
Old 01-18-2013 | 11:16 AM
  #899
Terminator2's Avatar
This. This is also why I have seen guys able run more timing on the dyno with no knock as the decreased load allows for more advance to be run vs what can be run under real world loads. For example 29* of timing an 0.85 PE lambda can be run on Coyote mustangs on the dyno on 93 octane without it knocking. On the street even at 0.82 PE lambda more than 27.5* will knock like mad even in 2nd or 3rd gear forget about 5th which is the 1:1 gear.
Old 01-18-2013 | 11:19 AM
  #900
Yeah that is normal. Did you try 4th gear instead of 3rd to load it up more. 4th would have likely made more power due to the loads increasing boost seen to 27-28 psi. What you saw with your car is the reason I do not like to dyno tune normally as we have no mustang dynos around here that can actually simulate a real world load better.
