Direct bolt-on turbo (ko4 replacement)
Old 03-25-2013 | 12:06 PM
  #1076
Terminator2's Avatar
Originally Posted by AARON-SS-TC
I would be dumb not to get a zfr or wr-2.
both are the same price and both have the features i am looking for, but the ZFR will make more power probably, so why not just get that one?...haha
I would get the ZFR if you want a straight bolt on and with no BOV to worry about setting up and leaking which is a good thing.
Old 03-25-2013 | 12:09 PM
  #1077
Holy crap. 460whp would be awesome
can the ZFR be ramped up to 28-30psi where it is maxed out and still be safe on 93 gas TO 6500RPMS?
If so, how much power are we thinking with full bolt-ons like me, at sea level here in Florida ON SOME DECENT TIMING or would fueling still be an issue???
On 93 with no meth ramping boost from 25 in the midrange to 28 psi should make 430 whp at 6500 ( probably more if you rev a bit higher)
  #1078
user 72239's Avatar
I want the BNR, but I dont know if i want to modify my DD that much
Old 03-25-2013 | 12:14 PM
  #1079
Originally Posted by Terminator2
Nice numbers on 93! I am starting Adrian's ZFR today. Just waiting on him to let me know if we are doing full E-85 with the 5th injector or if we are doing E-47 without. He is at nearly 6000 ft above sea level so fueling should not be an issue on E-47 even cranking the ZFR up to 29 psi. IIRC he made 357 whp 412 wrtq SAE on E-85 on the stock turbo at 5200 + altitude so should make great power on the ZFR. I am hoping it will see 460 whp at 29 psi (same absolute pressure as 25 psi at sea level)
Full E-85 with 5th injector it is on his car with the ZFR. I am sure he will dyno it after I finish tuning it so we can have some more ZFR numbers here very soon. It will be cool to see his gains vs the stock turbo on E-85.
  #1080
Omiotek's Avatar
You don't need to worry about that either with the wr2... it setups up just like a factory bpv. If you don't want the forge you dont need to get the forge. We will include a factory piece
Old 03-25-2013 | 12:21 PM
  #1081
AARON-SS-TC's Avatar
Originally Posted by terminator2
on 93 with no meth ramping boost from 25 in the midrange to 28 psi should make 430 whp at 6500 ( probably more if you rev a bit higher)
thats flippin golden, right where i wanna be at.
I have a forge bpv already.
The only thing i will be changing will be my intake set-up. I have the zzp tube/k&n filter set-up along with all the other zzp bolt-ons(intercooler,pipes, catted downpipe) and muffler delete.
I want either the k&n intake or the treadstone intake with the turbo that i get.
Omiotek - what kind of tune and gas was that wr-2 on to make 415whp/430wtq on the kappa?
BTW GUYS, MONEY HAS BEEN MY ONLY BARRIER NOW. MY RESEARCH IS OVER...LOL
Old 03-25-2013 | 12:40 PM
  #1082
Ok I was not sure so I did not want to say that. I know the BNR needs a BOV.
Old 03-25-2013 | 02:22 PM
  #1083
kdub1492's Avatar
Yea the WR3 and WR2 are both direct bolt on. Can use the forge bpv or the stock, doesn't really matter. AARON BUY A DAMN TURBO ALREADY!!!!
Old 03-25-2013 | 02:24 PM
  #1084
Shortbus's Avatar
What clutch is everyone using with the zfr, can stock hold 375+whp?
Old 03-25-2013 | 02:35 PM
  #1085
kdub1492's Avatar
I am using the Spec S3+ with my WR3, seems to hold quite well
Old 03-25-2013 | 02:45 PM
  #1086
Omiotek's Avatar
yeah i didnt think you were trying to be negative. just saying that they both accept a factory bpv or forge bpv as well as the factor boost control solenoid.
Old 03-25-2013 | 02:47 PM
  #1087
SunburstSS's Avatar
On Stock Clutch here....seems to hold pretty good, not sure why everybody says the stock clutch is shyt...
Old 03-25-2013 | 02:48 PM
  #1088
ULWizSS's Avatar
I am a LSJ but on a South Bend Stage 4 +
Old 03-25-2013 | 02:52 PM
  #1089
Thats cool. I would rather keep a factory style recirculated BPV than to run a BOV and the factory boost control is so much better as far as drivability than any MBC or EBC out there. Some people like the noise of a BOV but IMHO it is annoying and they can be more of a headache as far as sticking and leaking.
Old 03-25-2013 | 02:56 PM
  #1090
Spec 3+ is a very nice clutch. It drives like stock but holds like crazy.
Old 03-25-2013 | 03:02 PM
  #1091
Omiotek's Avatar
^^^^truth. paired with a aluminum flywheel its ever better imho. great feel it takes a lot of abuse. for as much abuse as i put my car through. the trans never failed.
Old 03-25-2013 | 03:10 PM
  #1092
I think my question got skipped...lol
Old 03-25-2013 | 03:40 PM
  #1093
soundjunky's Avatar
I was looking into these recently, and am breaking my silence to just try to clarify one point;
it looks like pretty much all these "bolt on" turbos require a custome hot side charge pipe, or at a minimum a different adapter/elbow to connect to the existing charge pipe;
Am I correct?
Old 03-25-2013 | 03:50 PM
  #1094
Yes, especially the ZFR, it needs the extender elbow from ZZP or cx racing has one that is a little cheaper but may need to be trimmed.
Old 03-25-2013 | 04:14 PM
  #1095
Omiotek's Avatar
93 octane and its a mild tune. Nothing super aggressive.
Old 03-25-2013 | 04:32 PM
  #1096
Fastgti69's Avatar
Interested to see the numbers for e47 with the 5th injector kit. I was running out of fuel at like 24/25 psi with e47. Would love to see numbers for 29 psi. I was forced to use 100 octane to go up to 28/29 psi, I don't have the 5th injector kit.
Old 03-25-2013 | 04:43 PM
  #1097
At his altitude though 29 psi is like 25-26 psi at sea level due to his baro pressure being 78-82 kpa vs 100-101 kpa at sea level.
Old 03-25-2013 | 04:45 PM
  #1098
Stamina's Avatar
Am I correct?
I was researching this for several weeks. The ZFR doesn't have an extended snout bolted on the end like the K04 does, so it requires extra length from the hotside to be able to connect it up, usually in the form of a coupler extension.
As far as the ZFR:
- The ZZP hotside works
- The Injen hotside works if you have a coupler extension
- ZZP stated the Hahn hotside can work, but didn't specify how easily
- The CIA hotside does not work (the boat I was in), though ZZP offered to weld a 2" tip on the ZFR or lengthen my hotside pipe
There may be others that would work, but would require some adaptation, or at least a coupler extension at a minimum. The ZFR is ~2" radius outlet, so a 2.5" radius hotside pipe end like mine would require a reducer of a longer length, which nobody seems to make.
As far as the ZZP hotside, it's incomplete, and uses the stock rubber tubes to complete it. If you don't have those anymore or aren't comfortable with using those in an increased boost application like this, you can buy the upgraded strength silicone tubes from them.
Old 03-25-2013 | 05:00 PM
  #1099
Shortbus's Avatar
My plan is to Order zzp's intercooler kit when I place an order for the zfr and use their coupler. I already have their castles d/p and k&n Sri, will also be getting a forged bpv so that should complete everything I need.
Also need to find a new tuner in md/va area, as my very good tuner that tuned my lsj moved to the west coast.
Old 03-25-2013 | 05:13 PM
  #1100
As far as the ZFR:
And make sure you get the thickest silicone couplers they offer as I have seen the thinner ones blow at only 23 psi on 2 LNFs I tuned (ZZP replaced them with the better thicker ones no charge).
