Direct bolt-on turbo (ko4 replacement)
Old 03-27-2013 | 01:14 PM
  #1151
Omiotek's Avatar
it will make a difference as ours is setup for stock so we would absolutely have to have your manifold to make it work properlay and weld the bung in the correct spot.
Old 03-27-2013 | 02:49 PM
  #1152
Fastgti69's Avatar
Crap, I mean that obviously makes total sense.
Old 03-27-2013 | 03:05 PM
  #1153
SunburstSS's Avatar
I Dyno tomorrow...Cant wait !
A stock SS/TC dynod at 230whp/220wtrq last week on the same dyno, lets see what my setup will get
Old 03-27-2013 | 03:22 PM
  #1154
Fastgti69's Avatar
That is reallly good that you have a base. Start a thread and load up the base file dyno for now.
Old 03-27-2013 | 05:20 PM
  #1155
oldskool's Avatar
Originally Posted by 40rty
Cool thing about the WR-x's is that they work well with the Kappa. The ZFR(on Kappa's) was having some clearance issues and Oldskool was working with ZZP about it but I haven't heard anything else.
Apologies for the lack of updates. ZZP has been fantastic both in communication and accommodating my build. They came up with a custom WG bracket and different BW WG actuator. Power steering reservoir relocate is a must, as is cutting up the black bracket that holds the reservoir and fuse box. The stock connection to the airbox doesn't fit the compressor inlet. Other than that, it's all good. In between snow storms and tuning other peoples cars, I'm working on a 15 psi tune and getting the boost in as early as possible. Even on 15 psi from the ZFR, I'm seeing more air through the MAF than the K04 on 22-23 psi (max 32 lb/min vs max 38 lb/min). Overall, I'm very happy with it so far.
Old 03-27-2013 | 08:03 PM
  #1156
Sully20's Avatar
Originally Posted by kdub1492
It's a big turbo, fitment was a big issue honestly.
I made 412/425 on 93 with 14* up top and 24.5#'s
How was spool time with the WR3?
Old 03-28-2013 | 05:40 PM
  #1157
SunburstSS's Avatar
Dyno'd my ZFR setup today
The Numbers were : 355whp/327wtrq
https://www.cobaltss.net/forums/dyno...inally-295525/
Old 03-28-2013 | 05:41 PM
  #1158
ULWizSS's Avatar
Nice numbers conservative tune i would expect. Reading the info on it now
Old 03-28-2013 | 05:56 PM
  #1159
Terminator2's Avatar
Type of dyno? Correction factor? Boost used? 91 or 93 octane?
Old 03-28-2013 | 07:50 PM
  #1160
SunburstSS's Avatar
It was on a Dynojet, these are uncorrected numbers, the SAE numbers would make a grown man cry lol, I have the turbo spooling full 23 psi at 4000rpm and ramping before that. This was on 93 gasoline & timing ramped up to 15 degrees up top
Old 03-28-2013 | 09:24 PM
  #1161
Shortbus's Avatar
Congrats!
Old 03-28-2013 | 11:20 PM
  #1162
AARON-SS-TC's Avatar
looks like 430whp on 93 is not feasable Term
Old 03-28-2013 | 11:30 PM
  #1163
kdub1492's Avatar
Don't be so set on numbers man. Dyno's ARE FOR TUNING. I have been in the same car (mine) that felt fast, and pulled harder making less power. It's all in the tuning. You are working with one of the best tuners, he will have your car running strong and safe at 400
Old 03-28-2013 | 11:52 PM
  #1164
oh believe me, i know, TERM2 is awesome.
Old 03-29-2013 | 12:24 AM
  #1165
Stamina's Avatar
Thank you for pointing this out. People get so caught up on numbers sometimes and forget the purpose of a dyno.
Old 03-29-2013 | 04:24 AM
  #1166
Omiotek's Avatar
yep. people all seem to expect more and more and more. like i tell people if you send up making good numbers on a mustang expect even better numbers on a dynojet
Old 03-29-2013 | 05:24 AM
  #1167
40rty's Avatar
Term2 is an amazing tuner.
Old 03-29-2013 | 07:44 AM
  #1168
ULWizSS's Avatar
I made 427/381 on my ZFR LSJ setup with 21psi so i dont see why not.
Old 03-29-2013 | 08:19 AM
  #1169
ULWizSS's Avatar
Attached my Dyno Sheet
Old 03-29-2013 | 03:03 PM
  #1170
strazdice's Avatar
Ya but it is soon forgotten, all they care about is the numbers not how the car runs
Old 03-29-2013 | 03:04 PM
  #1171
Fastgti69's Avatar
^^ good graph and nice curve. I still think ZZP's dyno reads high lol.
Old 03-29-2013 | 05:50 PM
  #1172
its all about the numbers....not
of course I am concerned about the power band. Hell, it could be a 1000whp, but for only 1k rpms, so who would care///
I want power through out the whole powerband.
Old 03-30-2013 | 08:35 AM
  #1173
ULWizSS's Avatar
Well i will be on another dyno here soon again once we add another meth nozzle and retune, bump up some timing etc.
Its a tuning tool nothing else. I could care less what it made honestly, i dont look at things that way only dyno queens do IMO.
I care about what it runs at the track. Those times dont lie.
Old 03-30-2013 | 10:10 AM
  #1174
Yes it does. I believe they fudge the weight and CD to make it read much higher than a mustang dyno should. They had a BNR 2871 car with a 2.1 and cams at 27 psi make 460 whp on that dyno which should be 500 whp on a dynojet which is not possible. IMHO that car would make around 410-420 whp on a properly calibrated dyno.
Old 03-30-2013 | 10:20 AM
  #1175
EFR flows at lot more at 28-29 psi than it does at 20-21 psi. The BNR2871 over in puerto made over 400 whp and 390 wrtq at 24-26 psi on 93 octane and I believe the EFR is more efficient at higher compressor speeds (torque holds longer which will translate into more hp up top) I think it can be done
