Direct bolt-on turbo (ko4 replacement)
Old 08-13-2013 | 08:41 PM
  #1351
Wert842's Avatar
One of your posts from the thread, Social Ecotec Specialists, you clearly posted saying you have a 300z and a cobalt ss with 380whp/410wtw... I guess no one can see your existing posts though.
Not arguing. You came in here saying one thing, then posted different numbers. To me, something didn't add up.
Sent from my Samsung Galaxy S4 using CobaltSS
Old 08-13-2013 | 09:24 PM
  #1352
simonlamprecht's Avatar
That is not my numbers bud I have a buddy with a 20g making that but he blows his **** more then he drives it. Regardless I'm looking for a turbo if you think my numbers a bs OK not ur car. I'm just trying to find something that can create good boost levels without stupid amounts of heat if u have an answer great.
Old 08-13-2013 | 09:26 PM
  #1353
ATLsilverSS's Avatar
^^^s400
Old 08-14-2013 | 06:54 AM
  #1354
taintedred07's Avatar
Originally Posted by 09CobaltSS1
Riiiiigggghhhhtttt.... 351whp/400wtrq on 21psi? What did you baseline at on the stock tune, 320/340? Lol
I know that wasn't the point of your post, but I couldn't help but comment on the silliness.
Umm e85 numbers with cams, no way in hell that's stock turbo on pump
Old 08-14-2013 | 10:05 AM
  #1355
Omiotek's Avatar
just post your dyno graph or logs and if your legit people will shut up.
as far as heat.....you have a turbo man they all produce A LOT of heat....efrs the way to go in my honest opinion.
Old 08-14-2013 | 11:25 AM
  #1356
Turbo dose produce a lot of heat but I'm talking about the air charge. What is the efrs flow rate?
Old 08-14-2013 | 12:45 PM
  #1357
49lbs
Old 08-15-2013 | 04:29 PM
  #1358
daddycollazo's Avatar
Originally Posted by C_A_D88
Just hit 403/373 on 94 15* timing up top on the zfr
Love the power band
but bnrgt2871 revised,, just hit 407/403 on 93 oct. same hp..less money
Old 08-15-2013 | 04:34 PM
  #1359
Wert842's Avatar
Waaaa waaaa. Numbers. Who cares about numbers. Numbers don't mean **** if you can't run your car.
Old 08-15-2013 | 05:28 PM
  #1360
alerosaint's Avatar
Do a lil searching there are quite of bit of options for the LNf . Bnr, zfr, wr3 just to name a few
Old 08-16-2013 | 11:33 AM
  #1361
Omiotek's Avatar
Bnr gt2871 cobalt SS - YouTube
Efr is a superior turbo with a lot more technology in it. If all you care about is numbers buy a cheap journal bearing turbo and be done. When you want all the bells and whistles it gets expensive
Old 08-16-2013 | 11:40 PM
  #1362
C_A_D88's Avatar
Was only running 24 psi also
Old 08-17-2013 | 03:55 AM
  #1363
GTOworshiper9's Avatar
lol at the hydrogen guy
Old 08-17-2013 | 12:47 PM
  #1364
Wert842's Avatar
I rock a flux capacitor along with a plutonic turbine.
Old 08-17-2013 | 08:49 PM
  #1365
40rty's Avatar
**** this ****. LS7 twin turbo going in next.
Old 08-17-2013 | 09:15 PM
  #1366
AARON-SS-TC's Avatar
dream motor set-up....lol
Old 08-22-2013 | 09:50 PM
  #1367
06RYSS's Avatar
saw on page 1 that the wr-1 can support up to 400 hp. I don't remember seeing anything on the onther 53 pages if anyone was actually running the wr-1 and can support this claim or not. my stock turbo is going out and i'm considering trying this one. also is it possible to run e47 with the wr-1 with the stock fuel system?
Old 08-22-2013 | 09:59 PM
  #1368
that wr-1 can support up to 360whp on 93 gas and 375whp on E-blend, but its still gonna die out earlier than the other upgraded turbos. that wr-1 is just a maxed out ko4+, but still responds like stock with high torque and midrange...
Old 08-22-2013 | 10:32 PM
  #1369
kdub1492's Avatar
Anyone want to buy the WR-3? Want to go with a different setup that doesn't include so much top end...
Old 08-22-2013 | 10:53 PM
  #1370
06RYSS's Avatar
aaron, so the wr-1 won't need zzp's lnf cams to run an e blend? and I get that it'll produce less than other, conventional, bigger turbos. but for the price range, as in between it, the bnr and the s20g, how does it compare? forgive my noobishness.
Old 08-23-2013 | 12:47 AM
  #1371
the ko4+ or wr-1 is a direct bolt-on and no modifying needed, the other turbos need to be modified to fit properly or needed and external bov added to work but produce more power and a longer range of it...
Omiotek says the wr-1 is very popular, and he is actually going to be switching to it...pm him for details.
Old 08-23-2013 | 12:49 AM
  #1372
too laggy for ya???
didn't you make 415whp/430wtq on a mild tune?
Old 08-23-2013 | 01:00 AM
  #1373
06RYSS's Avatar
good info. thanks
Old 08-23-2013 | 01:09 AM
  #1374
good luck man
Old 08-23-2013 | 09:06 AM
  #1375
kdub1492's Avatar
Originally Posted by AARON-SS-TC
too laggy for ya???
Yea too leggy for what I want to do. But yea I put down 433/430 on the same tune with the 4" intake
