Direct bolt-on turbo (ko4 replacement)
#1401
I don't think I've seen that one before, or at least if I did I don't recall. I was referring to this graph from the official dyno thread actually.
http://i1140.photobucket.com/albums/...ps404bb5f9.jpg
Sent from my Samsung Galaxy S4 using CobaltSS
#1403
Wonder if its the one I posted or the one 09 posted. If its the one I posted and its on the same tune, moving from a 3" to a 4" intake increased spool time by 400 rpms.
#1404
So I finally got on the dyno with my zfr the other day and figured this would be an appropriate thread to post the numbers. She put down pretty much exactly where I wanted to be power wise (421/407) so I'm quite content with where the power sits as of now. There's actually still more in the turbo if I do ever decided I need more power for whatever reason, but at this point I don't really see that happening. Here are the graphs of my stock turbo on e47 @ 25psi vs efr6758 on e35 @25.5psi. Both graphs were done on the same exact dyno, with the same mods (aside for the turbo and fuel of course) and were about a year apart in similar conditions. A 71whp gain with similar boost levels isn't so bad I would say..
#1407
#1409
lol.. hey now! I got sick of tuning all these nice turbo upgraded cars and not having anything to show for with my own damn car. I was beginning to feel a tad inadequate.
I'm still far from making big power by any means, but it's definitely a nice little bump up in the power department..
Are you still doing the 10 year debate over there, or are you ever going to finally pull the trigger on a larger turbo?
#1410
#1412
#1413
The turbo is definitely working out quite wonderfully thank you very much sir. Now it's time to get your ride back on the road again!
Spool time is definitely good, but very different than stock. It takes a little getting used to, or at least for me it did. You get so used to boost on demand at basically any rpm that it sort of spoils you a bit. It's honestly not bad at all though. The low end is still without a doubt there. I actually limit my boost ramp pretty similarly to the stock turbo (full boost by about 4200rpm) to avoid any sort of boost spikes so my engine and trans hold together for at least a little while. Even at that, I still made 406wtrq by like 4400rpm.
Thanks man! E85 is a wonderful thing, let me tell you..
#1414
2 60-120 pulls in my car. They look slower than they are. First run I ran 3.83 60-100. Second run, I ran 3.58 60-100. Fully bolted, Zfr, 4.45 Trans, and on 93.
#1416
#1417
A 3.58 60-100?? The 4:45 ratio makes that much of a difference huh? Is that log verified just out of curiosity?
Hey now buddy! Leave my oddball eblend alone! Lol.. You might be surprised how well the car responds to e35 vs e47 with a larger turbo. My fueling system in particular is loving me. I see zero rail pressure drops at wot, and I don't have to kill my injection window in order to keep everything in check. Plus I'm actually able to run the exact amount of timing as I was with e47. Kind of a win-win if ya ask me..
#1418
4.45 makes a huge difference I'm putting down 4.0's. It's insane the difference that it makes. Yeah your mpgs suck but it's totally worth it lol.
Wert seeing those numbers makes me excited to see what my car does when I get my zfr on since ill be on full e I remember you saying you can't get e where your at but Ik that you can buy it by the 55 gallon drum as e98 then just mix it to be e85 and bam! More powweerrr.
#1419
My best time on my ko4 with e47 was a 4.09, so it is doable, but I'd still be curious to see a 3.5 on 93 in a log. I pull pretty consistent 3.6-3.7 60-100's at 421whp, granted it's on the stock trans, but I'd still be curious to see it in a log. I'm not saying it's not possible. I'm just the type of person that likes hard numbers in graph or spread sheet form..
#1420
I went on vacation to Hershey and still managed 37mpg on the highway at 70mph at 3k basically the whole way along with doing a couple pulls here and there. Got 210 miles on a half tank. Lol. On the way back though, I was a little bit more ruthless and was being a badass and managed 32mpg. Every since Saturday night I'm at 25mpg through everything.
#1422
#1424
Looks fast as hell Wert. That 4.45 tranny definitely makes a different. I feel a difference going from the 3.82 to the 4.05 LSJ tranny and I can't imagine how much different yours is. I need to get my **** running asap **** my life.
#1425
Here's a few from bimmerboost 60-130 times
3.53 - Underground / TT Gallardo / 2-shifts
3.96 - KPG / EVOMS 996TT 1.1% decline with 0-shifts (4th gear pull). RWD, app. 3300 lbs, E85 at 25 psi (app. 850 rwhp).
4.09 - Acicchelli / TT Gallardo / 1-shift
4.52 - jbsteven / SC&TT Ford GT 994 rwhp / 1-shift
4.53 - HoustonT / 880 rwhp Supra / 1-shift
4.87 - Oz / Supra / 1-shift
5.07 - TwinTurboM3 / TT E46 M3 @ 25psi / 1-shift
5.14 - Hllywood / TT Viper / 93 octane/ 2-shifts
5.27 – Lil Powell / C5 Vette with big motor and NOS
5.74 - Divexxtreme / Supercharged C6 Z06 / 1-shift
5.88 - Blacksheep / Supercharged C6 Z51 Corvette / 1-shift
6.59 - DadsC63 / C63 AMG, MHP v4 CDT, MHP LT Headers & Mids, MHP 3" Race Catback + Xpipe, MHP Thermostat, 125 shot nitrous, CF hood/trunk, Race Gas, DR's GRAPH
6.65 - Acicchelli / Renntech SLR
6.66 - Dad's C63 - C63 AMG - MHP Tune, 125 shot nitrous
6.85 - gringointegra / TC'd Acura Integra, 1-shift
6.89 - Vrybad / C5 Z06TT (APS Turbo, no cats, stock muffler, 573 rwhp @ 9.5 psi) / 1-shift
6.93 - GTRHU / Nissan GTR / Cobb AP NIS-006, GTC custom map, E85 map running, JoeGr Beta LC map, GTC catless downpipe, Titek sus midpipe, HKS legamax catback, Forge actuator(red spring), ID1000cc injectors, Custom 76mm intake, HKS spark plugs, Greddy Intercoolers, Harman Motive IC hardpipe kit. GRAPH
7.05 - Divexxtreme / 2010 GT-R, Switzer cat-back exhaust, drop-in air filters and Switzer 100 octane tune, peak boost 18 psi
7.24 - Acicchelli / Stock SLR
7.48 - Acicchelli / Renntech SL65 AMG
7.59 - Blacksheep / C6 Corvette Z51 (heads/cam, 484 rwhp) / 2-shifts
7.74 - 458 Italia, stock / GRAPH
7.74 - HoustonT / GT-R / 640 HP (downpipes, y-pipe, BC, hard IC pipes, custom tune)
7.85 - Acicchelli / Stock LP640 / 2-shifts
7.86 - Divexxtreme / Stock C6 Z06 / 2-shifts
7.95 - Byzantine / '06 Gallardo 6-MT, catless exhaust & 105lb weight reduction, 2-shifts
8.00 - loco cinco cinco / W211 E55, OE Custom tune, 180mm Pulley, 82mmTB, Kleemann Headers with full 3" Exhaust, Labonte Meth kit, 16" e320 wheels, Quaiffe Diff.
8.04 - MPH / SL65 / MHP Tune / DR's GRAPH
8.16 - 930chas / E55 AMG, Evo 178 Pulley, 82mm TB, OE Tuning Tune, Labonte S2 Methanol Injection, Quaife LSD, exhaust, headers GRAPH
8.19 - Jeremy - OE tuned C63 AMG / Gintani full exhaust and headers, K&N, 100 oct, DR's GRAPH
8.24 - DrivenAgain / CL600 AMG
8.31 - biglare / SC'd E90 M3 DCT / 2-shifts
8.41 - TMC CL65, '09 CTS-V with 8.6" pulley, CAI, LS7 ported TB, headers w/ cats, heat exchanger
8.40 - bassn_07, E5 with full bolt-ons
8.45 - TMC CL65 / Kleeman CL65
8.46 - Dads C63 / MHP - L/T Headers, Heads, Tune, intake gaskets, C/F airbox with K&N Filters.
8.58 - Jeremy - OE tuned C63 AMG / Gintani full exhaust and headers, K&N, 91 oct GRAPH
9.41 - Propain - C63 AMG, OE Tuning tune, DR's, Race Gas, airbox mod/filter GRAPH
9.42 - Easy2Speed / stock 2010 CTS-V / 1-shift
9.65 - DD GT3 RD - 997.2 GT3 - Sharwerks muffler delete GRAPH
9.67 - Propain - C63 AMG, OE Tuning tune, DR's, Race Gas, airbox mod/filter GRAPH
9.74 - JonsC63AMG, OE Tuning tune, GRAPH
9.79 - DD GT3 RD - Stock C63 w/ P31, 91 oct GRAPH
9.92 - Byzantine / '06 Gallardo 6-MT, 2-shifts
10.13- Acicchelli / Stock F430 / 3-shifts
