Direct bolt-on turbo (ko4 replacement)
Old 09-30-2013 | 08:42 PM
  #1676
So what clutch are all you bigger turbo guys on? I know Wert has a KY Stage 3.
Old 09-30-2013 | 08:52 PM
  #1677
09CobaltSS1's Avatar
Originally Posted by Wert842
Lol. It's the turbo gasket. Looks like it's in 3 pieces. I already ordered one from a dealer and should be here tomorrow or Wednesday.
It's a bit of a pain in the ass, but at least it's nothing serious. Odd that it busted like that though.
I'm actually running the kys3 as well.
Old 09-30-2013 | 08:56 PM
  #1678
Fastgti69's Avatar
I had ky stage 3. The stage 4 is better if you can get it. 4 puck. Weird as it sounds, but its way better than the stage 3 and thats a 6 puck.
Old 09-30-2013 | 09:09 PM
  #1679
Anybody with ZZPs Southbend Stage 4?
Old 09-30-2013 | 09:14 PM
  #1680
andrewcarr1993's Avatar
Turbo came back from BorgWarner today. If you didn't know that the compression wheel was damaged you wouldn't be able to tell it ever was. They included new gaskets and replaced a few parts on it. All said and done I only paid the shipping to them. Great company to deal with in my opinion even if it is out of warranty.
Old 09-30-2013 | 09:22 PM
  #1681
kdub1492's Avatar
I have Spec S3+
Old 09-30-2013 | 09:27 PM
  #1682
Wert842's Avatar
That gasket was a new one and replaced when I installed the zfr. Only has like 4k miles on it if that. Still not going to rule out everything just yet, but that's the only thing I've found wrong or messed up do far. Oil lines look fine and definitely aren't clogged or anything.
Is any one else's oil return line that bolts to the bottom of turbo turn black at all? Mine had like a slight coating of black on it but wiped off. Probably just a little oil.
I wanna get a spec 3+ or an fx300.
Sent from my Samsung Galaxy S4 using CobaltSS
Old 09-30-2013 | 11:36 PM
  #1683
kdub1492's Avatar
I like my Spec thus far. It's seemed to hold everything I've thrown at it. 400+ hp/tq and tons of dyno pulls
Old 10-01-2013 | 12:33 AM
  #1684
Gunney_07's Avatar
stock clutch and holding like a boss
Old 10-01-2013 | 01:38 AM
  #1685
Omiotek's Avatar
spec stage 3+ here too paired with an aluminum flywheel.
Old 10-02-2013 | 11:19 AM
  #1686
Dart_SI's Avatar
Gmpp and it holds great
Old 10-02-2013 | 01:29 PM
  #1687
Wert842's Avatar
Gunney and John are you guys still meeting up for runs?
Old 10-02-2013 | 02:31 PM
  #1688
Gunney_07's Avatar
Are you out?
Old 10-02-2013 | 04:16 PM
  #1689
Wert842's Avatar
Most likely unless I can get off a day and figure out if something else is wrong other than the gasket blowing out. It was suppose to be here yesterday or today but now its not coming till tomorrow morning. Its gonna suck rushing it all. Lol.
Old 10-02-2013 | 05:34 PM
  #1690
Gunney_07's Avatar
Not wworth rushing and overlooking a potential problem... hey 09 when is this dyno meet up thing you mentioned earlier?
Old 10-02-2013 | 05:58 PM
  #1691
AaronJ's Avatar
Idk how some of you are running the stock clutch on such power
Old 10-02-2013 | 06:00 PM
  #1692
user 72239's Avatar
im not on big power, but I have been tuned for a year and still have stock clutch @ 77k miles.
Going WOT above 3k helps
Old 10-02-2013 | 06:29 PM
  #1693
Where can you get the Spec 3+ from?
Old 10-02-2013 | 09:10 PM
  #1694
Wert842's Avatar
Ttr I do believe sales it for sure. If not go straight to spec about one.
Side note on my progress... Can't just move the turbo a little bit to put the new gasket on. I started tearing the O2 housing back off and it started getting dark and annoying working with a light. Just gonna wait till tomorrow to rip it all off and put the new gasket in. So far though, the gasket is in 3 pieces and in half. Lol.
Old 10-02-2013 | 09:34 PM
  #1695
GoodLuckBro's Avatar
Does that mean another ZFR went bad? I didn't read the whole scenario.
Old 10-02-2013 | 09:41 PM
  #1696
At the moment all he knows is that the exhaust gasket blew apart.
Old 10-02-2013 | 09:44 PM
  #1697
Sure, I might still be down to meet up with just Gunney if he wants.
It's next weekend actually, 10/12 to be exact. You're definitely more than welcome to join us if you're up for it. We're all heading over to Sonic after for lunch as well so it should be a good time..
Old 10-02-2013 | 09:47 PM
  #1698
Wert842's Avatar
I'm 99% the turbo is good and just the gasket blew apart. Only thing I have come across so far. The gasket is completely worthless. Everything I have looked over though looks fine. No shaft play at all, compressor wheel is still clean and crisp, oil lines are perfect and flowing, coolant lines are fine, and when I drove it home sunday, it still built boost and held it. It just had a different sound to it, but definitely sounded like an exhaust leak of some sort.
Damn CT people. I want Sonic... Only ever had it once!
Old 10-02-2013 | 09:48 PM
  #1699
Yes just a small exhaust leak
Any of you guys have a suggestions as to where I should tap into my coolant for running lines to my EFR.
Old 10-02-2013 | 09:51 PM
  #1700
Wert842's Avatar
Can't you just use the spots for the coolant lines from the K04? Or don't you have an LNF?
Small exhaust leak, definitely... While under the car though I also noticed a hole the size of a BB in my muffler which could be the cause of my nasty exhaust sounds during decal.
