E85 and Boost Question
So buying an LNF this week.. Thankfully sold the LSJ.
So, my question is. If I ran simple bolt on's (Intake, DP, Charge Pipes, Catback) and ran on E85, would I be able to reach the same power levels on a lower Psi compared to 93 on a higher Psi with an intercooler, so I don't have to dish out the $350 for intercooler right away? Might be a dumb question.. if so. My bad..
If you can get a return for cheap then I guess you could go that route.
Or run stock intercooler with full psi tune until it breaks.
Has anyone actuallgained much HP from aftermarket intercooler? I always thought it reduced the time to cool back down. Stock intercooler isn't that restrictive. Its just plasticend tanks that eventually break.
A bigger IC doesn't make more power. It reduces heat soak when you're generating more heat. E85 helps cool a little versus pump gas. I was on a ZZP canned tune and otherwise bone stock and had no issues, including regular road track days that are worst case scenario.
^^ this that's why I said you only need it for higher power levels where the added cooling/IC core size would actually benefit you
Turning off "traction-control", will help save, stock charge pipes, & intercooler,
from "boost-spikes"...
Somehow, when traction-control kicks in, the ECM will quickly slam shut,
the throttle blade, causing a dangerous boost-spike....,
that can blow-up the stock plastic stuff.
This happens more when "tuned", because of higher boost.
